Favorite ilogic rules?
lesmfunk
lesmfunk
What is your favorite ilogic rule that you are using and what does it do? Not asking for code, just basic description.
Mine is exportDXF which automatically creates flat pattern and dxf from sheet metal part once set to released and saved.
Owner2229
Hi, mine are these:
DXF exporter - creates Flatpattern, places part number on in, asks for confirmation and exports it.
Excel export - triggered from assembly. Takes all sub-assemblies and parts and exports all info about it to excel file (part nr., description, stock, quantity, where is PDF and/or DXF located etc...).
IS exporter - triggered from assembly. Takes all PDFs and DXFs and copyes them to our information system.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
rhasell
I have a two favorites: (Its really hard to narrow the list down)
1: "Change Component type" - Sets the a variety of values parameters, and material type to a part, to set-up the BOM, based on the use/type of part.
2: "Replace derived component" - does exactly that, this is GOLD. (Think I got that one from Curtis)
Reg
2026.1
