How to get Bend added automatically
I am working in Sheet metal enviroment, where I am creating a sweep, giving a profile and 'L'Shaped path.
Using same (following) code to prepare the path. In one case its adding a fillet at the corner in the path, but in the other, its not adding so. Why? What could be the reason. Actually, I want Bend to get added all the time, consistently. Anything to do with overall part dimensions relative to Bend-Radius?
       Private Function CreatePathForFlange(ByVal oPl As Inventor.Polyline3d, ByVal normal As Vector, ByVal awayDir As Vector, ByVal offsetdistance As Double, ByVal heightdistance As Double) As Inventor.Path
            Dim point1 As Point = oPl.PointAtIndex(1)
            Dim point2 As Point = oPl.PointAtIndex(2)
            Dim point4 As Point = oPl.PointAtIndex(3)
            '                                                    pt3
            '                                                 /   |pt2
            '                                               pt4 /
            '                                   <-- uv3      |/
            '                            pt5 -------------- pt1
            '                   uv4 |     |
            '                       v     |
            '                             pt8
            Dim uv3 As UnitVector = normal.AsUnitVector
            Dim planarOffsetVector As Vector = uv3.AsVector
            planarOffsetVector.ScaleBy(offsetdistance * 3)
            Dim point5 As Point = point1.Copy()
            point5.TranslateBy(planarOffsetVector) ' TRANSLATE by Offset distance
            Dim uv4 As UnitVector = awayDir.AsUnitVector
            Dim vertticalHeightVector As Vector = uv4.AsVector
            vertticalHeightVector.ScaleBy(heightdistance)
            Dim point8 As Point = point5.Copy()
            point8.TranslateBy(vertticalHeightVector)
            Dim wpt1 As WorkPoint = m_compDef.WorkPoints.AddFixed(point1, True)
            Dim wpt5 As WorkPoint = m_compDef.WorkPoints.AddFixed(point5, True)
            Dim wpt8 As WorkPoint = m_compDef.WorkPoints.AddFixed(point8, True)
            Dim oSketch3d As Sketch3D = m_compDef.Sketches3D.Add
            Dim skln1 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(wpt1, wpt5)
            Dim skln2 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(skln1.EndSketchPoint, wpt8)
            Dim oPath As Inventor.Path = m_compDef.Features.CreatePath(skln1)
            CreatePathForFlange = oPath
        End Function
adam.nagy
Autodesk Support
Autodesk Support
What happens when you add the sweep through the UI? Is the bend always automatically added then?
Cheers,
Adam Nagy
Autodesk Platform Services
To address this inconsistent behaviour I am adding a Bend myself, as follows:
            Dim skln1 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(wpt1, wpt5, False)
            Dim skln2 As SketchLine3D = oSketch3d.SketchLines3D.AddByTwoPoints(skln1.EndSketchPoint, wpt8, False)
            Dim skarc As SketchArc3D = oSketch3d.SketchArcs3D.AddAsBend(skln1, skln2, m_bendradius)
Seems to work ok, when there is enough space for bend to get created, else errors out.
For now, this looks ok, right?
adam.nagy
Autodesk Support
Autodesk Support
Well, if it works consistently then I guess it's OK.
Adam Nagy
