Extracting points coordinates form a sketch using VBA to excel
jeeva.scientist
Message 1 of 12
jeeva.scientist
Hello everyone,
  • I have created a sketch with constriction lines and placed some points, on the sketch as a guide path.
  • I want to extract the coordinates of all points and export to excel. (Using VBA iLogic)
  • Points are created using sketch points.
  • I just want to extract the coordinates for sketch points that created manually. (not for line endpoints and arc endpoints)
  • I have attached the sketch image for reference, thanks in advance.Picture1.png
Replies (11)
Message 2 of 12
frederic.vandenplas
'VBA CODE add a reference to microsoft excel xx.0 Object library
Sub ExportSketchPoints() Dim oExcelApp As Excel.Application Set oExcelApp = CreateObject("Excel.Application") oExcelApp.Visible = True Dim wb As Excel.Workbook Set wb = oExcelApp.Workbooks.Add Dim osheet As WorkSheet Set osheet = wb.Sheets(1) Dim oPartDoc As PartDocument Set oPartDoc = ThisApplication.ActiveDocument Dim oPartCompDef As PartComponentDefinition Set oPartCompDef = oPartDoc.ComponentDefinition 'Get the first sketch in the model Dim oSketch As Sketch Set oSketch = oPartCompDef.Sketches.Item(1) Dim oSketchPoint As SketchPoint Dim x As Integer x = 1 osheet.Cells(x, 1).Value = "x" osheet.Cells(x, 2).Value = "y" x = 2 For Each oSketchPoint In oSketch.SketchPoints 'Values in cm osheet.Cells(x, 1).Value = oSketchPoint.Geometry.x osheet.Cells(x, 2).Value = oSketchPoint.Geometry.Y x = x + 1 Next End Sub
'ILOGIC CODE
AddReference "Microsoft.Office.Interop.Excel" 'To use excel
Dim oExcelApp As Microsoft.Office.Interop.Excel.Application
Dim wb As Microsoft.Office.Interop.Excel.WorkBook
xlwb = oExcelApp.Workbooks.Add
Dim xlws As Microsoft.Office.Interop.Excel.Worksheet
xlws = xlwb.Worksheets(1)
Dim x As Integer
x = 1
xlws.Cells(x, 1).Value = "x"
xlws.Cells(x, 2).Value = "y"
x = 2
'Values in cm
xlws.Cells(x, 1).Value = oSketchPoint.Geometry.x
xlws.Cells(x, 2).Value = oSketchPoint.Geometry.Y
x = x + 1
Next
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 12
jeeva.scientist
hello,
Thanks for your response, I used the iLogic code its works. but it is also considering the other points such us
  • circle center point,
  • projected origin point,
  • and also endpoints of a line.
is there a way to extract only the sketch points that are created manually. (ie. excluding the above-mentioned points).
as you mentioned it is in "cm" in excel. is there a way to get it in "mm".
thanks, again for the support.
I have attached the image for further reference.
Message 4 of 12
frederic.vandenplas
There are different approaches possible, below 2 possibilities, the one uncommented is best i think
conversion is commented
'If oSketchPoint.HoleCenter = True Then
If oSketchPoint.AttachedEntities.Count = 0 Then
'Values in cm by default , multiply by 10 to get mm (other approaches possibly with UOM conversion)
osheet.Cells(x, 1).Value = oSketchPoint.Geometry.x * 10
osheet.Cells(x, 2).Value = oSketchPoint.Geometry.Y * 10
x = x + 1
End If
Next oSketchPoint
Message 5 of 12
jeeva.scientist
Sorry, I am totally new to VBA.?
I have added your second code to the first code.
The unit is converted to mm, its a success.
but the center point and line endpoints are still there.
'ILOGIC CODE
Dim x As Integer
x = 1
x = 2
If oSketchPoint.AttachedEntities.Count = 0 Then '2nd code
End If
'Values in cm
xlws.Cells(x, 1).Value = oSketchPoint.Geometry.x * 10 '2nd code
xlws.Cells(x, 2).Value = oSketchPoint.Geometry.Y * 10 '2nd code
x = x + 1
Next
The reason I am trying to solve this is that I could not solve my other problem. if it's ok please take a look at this too, thanks.
https://forums.autodesk.com/t5/inventor-customization/creation-sketch-with-vba-ilogic/m-p/8998899#M1...
Message 6 of 12
frederic.vandenplas
'this
End If
'Values in cm
x = x + 1
Next
'should be
'Values in cm
x = x + 1
End If
Next
Message 7 of 12
jeeva.scientist
Hello, please check I don't know whether I have added correctly or not. I excel output i got 2 extra rows.
kindly find the part file attachment.
'ILOGIC CODE
Dim x As Integer
x = 1
'this
End If
'Values in cm
x = x + 1
Next
'should be
'Values in cm
x = x + 1
End If
Next
Message 8 of 12
jeeva.scientist
I am wondering what if I use work point instead of sketch point. wouldn't it be easy to find the coordinates? if its a work point. if it's easy to find the works point coordinates and export it to excel its enough for me.
in the above image, you can see that I have created work points in two different methods.
  • using a circular pattern.
  • using a rectangular pattern.
Output Expecting:
  • Count: total number of work points.
  • Coordinates of all work point exported to excel.
thanks.
Message 9 of 12
frederic.vandenplas
So you let me create code for a problem, i've created working code and now you change your question?
Anyway here you go 😀
Dim oWorkPoint As WorkPoint
Dim x As Integer
x = 1
osheet.Cells(x, 3).Value = "z"
x = 2
For Each oWorkPoint In oPartCompDef.WorkPoints
osheet.Cells(x, 1).Value = oWorkPoint.Point.x * 10
osheet.Cells(x, 2).Value = oWorkPoint.Point.Y * 10
osheet.Cells(x, 3).Value = oWorkPoint.Point.z * 10
x = x + 1
Next oWorkPoint
End Sub
Message 10 of 12
jeeva.scientist
I am getting this error,
Message 11 of 12
frederic.vandenplas
You did not add the reference to miscrosoft excel library
https://www.google.com/search?q=add+reference+vba&rlz=1C1GCEU_nlBE824BE824&oq=add+reference+vba&aqs=...
Message 12 of 12
jeeva.scientist
Thanks bro. it works perfectly. working proof.
