insert part if iFeature exist
martinhoos
martinhoos
Hi to all,
i am looking for a code that work with an assembly. If there exists a pipe with an iFeature named "LongPilot_EXT"  with Diameter Ø16 insert a specified part. I dont know how i shouldt do that.  😞
The iFeature has 4 various Diameters (but only one in each pipi) and so we have 4 various parts the we insert.
Maybe there i someone who has a code like this
Thanks alot
Regards from germany
Martin
HideoYamada
Hello martinhoos,
Here is sample code.
This code shows width of the slot iFeature.
Option Explicit
Const iFeatureTemplate = "End_mill_straight"
Const iFeatureParameterPrompt = "Enter Diameter"
Sub test()
    Dim aCompDef As AssemblyComponentDefinition
    Set aCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim occ As ComponentOccurrence
    For Each occ In aCompDef.Occurrences
        If TypeOf occ.Definition Is PartComponentDefinition Then
            Dim pCompDef As PartComponentDefinition
            Set pCompDef = occ.Definition
            Debug.Print pCompDef.Document.DisplayName
            Dim iFt As iFeature
            For Each iFt In pCompDef.Features.iFeatures
                Dim template As String
                template = GetBaseName(iFt.iFeatureTemplateDescriptor.LastKnownSourceFileName)
                If template = iFeatureTemplate Then
                    Dim iFtInput As iFeatureInput
                    For Each iFtInput In iFt.iFeatureDefinition.iFeatureInputs
                        If TypeOf iFtInput Is iFeatureParameterInput Then
                            Dim iFtParamInput As iFeatureParameterInput
                            Set iFtParamInput = iFtInput
                            If iFtParamInput.Prompt = iFeatureParameterPrompt Then
                                MsgBox "Part : " & occ.Name & vbCr & _
                                    "Diameter : " & iFtParamInput.Value & " cm"
                    Next iFtInput
            Next iFt
    Next occ
End Sub
Function GetBaseName(fullPath As String)
    ' You need add the "Microsoft Scripting Runtime" to the reference setting.
    ' If you cannot use this reference with some reason, you must write a code by yourself.
    Dim objFSO As New FileSystemObject
    GetBaseName = objFSO.GetBaseName(fullPath)
End Function
The model files are attached to this message also.
This macro is stored in the Module1 of Assembly1.iam
If what iFeature is used is known, you can know what part should be placed.
Good luck!
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
martinhoos
Hello Hideo Yamada,
thank you for the reply. I couldt not check your cad-data, because i work with Inventor 2015. Your code stopps at:
Maybe i do not have "Microsoft Scripting Runtime"
it will be easier for me to get a code written with ilogic
thanks alot
Regards Martin
martinhoos
Hello Hideo Yamada,
i changed only one line:  Const iFeatureTemplate = "LongPilot_EXT"
The code runs, but nothing happens...
Where is my mistake?
Regards Martin
HideoYamada
Try this :
Freeradical
 Hideo Yamada
HideoYamada
@martinhoos wrote:
Hello Hideo Yamada,
You should set iFeatureParameterPrompt also.
The macro identifies the parameter by the prompt message.
Set the string shown in the red circle to iFeatureParameterPrompt.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
martinhoos
Hello Hideo Yamada,
thanks again for your reply. The code runs!
Very best regards grom germany
Martin
