Adding Mate constraint using cylinder face axis
Jef_E
Jef_E
I am struggling to add a mate constraint between 2 cylindrical faces (axis to axis).
If I just constraint the faces it results in an triangle warning in Inventor.
How do you select the axis from a face with surface type kCylinderSurface and constraint it?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
' Constraint the planes axis
_Assembly.ComponentDefinition.Constraints.AddMateConstraint(oTubesheetFaceProxy, oTubeAxisFaceProxy, 0, InferredTypeEnum.kInferredLine, InferredTypeEnum.kInferredLine)
Use the optional input line
Inventor 2014 SP2
