Inventor Pro 2015>Tools>Options>iLogic Configuration>External Rule Directories>Add a Directory to the list>Browse for Folder
Unfortunatetly, I can't manually enter a location for adding an external rule directory. I have to browse for it. This presents a problem for a network location that doesn't display in the network list. Our networks team informed me that the "Browse for Folder" is old technology and that newer servers won't show in that list.
Any easy work around solution would be to map the network location. However, this presents problems when a user tries to work remotely over VPN. In this case, when a user starts their computer, the network location isn't immediately mapped. Until they log into VPN, the mapped network connection is lost. Even if this connection gets reestablished with VPN, it seems Inventor still thinks the map is broken. Even after verifying the map is good (first) and then opening Inventor for the first time since the machine has been turned on.
We use this network location as a central spot for the iLogic that is executed in our templates. It's critical to our workflow. Sure, we can have users copy the iLogic to a local drive, but then updates to code becomes much more difficult to manage. We can also store it in cloud storage such as dropbox or onedrive, but this also is a bandaid fix.
Do you know if there is a file I can have users manually edit in which this location can be manually entered so they don't have to map a network drive?
Example: \\VaultServer\Inventor Standards\Automation\ where \\VaultServer\ doesn't show in the network list of the "Browse for Folder" window.
