Export "DWG" select a face using a VBA macro
isocam
isocam
Can anybody help????
I have the following code that outputs an AutoCAD "Dwg" file of an extruded face. The output is a 2d profile.
        Dim oDoc As PartDocument
        Set oDoc = ThisApplication.ActiveDocument
        Dim oBaseFace As Face
        Set oBaseFace = oDoc.SelectSet.Item(1): THIS IS THE PROBLEM LINE!!!!
        Dim Cm As CommandManager
        Set Cm = ThisApplication.CommandManager
        Call Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,"C:\Test.dwg")
        Dim oCtrlDef As ButtonDefinition
        Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
        Call oCtrlDef.Execute
It works fine but I have to pre-select the face of the extrusion manually before running the macro. Does anybody know how to automatically select the face using the VBA macro rather than manually selecting the face first?
All I am doing is creating a sketch (Lines/Arcs/Circles) then extruding the sketch. Nothing else!
Many thanks in advance!!!!
Darren
andypugh
I think that you can do this without a macro, I seem to recall a right-click option to export a face.
(I am waiting for re-installation on a new PC so can't check today).
Your VBA should be able to iterate through all faces and choose one, but how will it know which one you intended to export?
May be:
SyntaxEditor Code Snippet
 Dim testFace As Face
                 Try
                 testFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
                 Catch  ex As Exception
                 End Try
                    If (testFace Is Nothing) Then
                        Return
