External data source to drive constraint
Is it doable to have and external Nob or level drive a constraint in inventor?
Say i get position data over a serial-port from a external pot. I have a program to capture the data.
Can i drive a constraint i inventor with this?
Use case is open or close a claw or a gripper with a physical device.
I think this will be a good help while modeling around a gripper.
Jef_E
I think this should be do-able if you can capture the data and then sent it to the right constraint(s) but you will need to manage it with events I guess each time the data captured changes it should drive the constraint.
If you can manage that driving the constraint via an application is not hard.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Yea a small micro controller and a python program can get the data without a problem.
But can i get a pointer on how to pipe this in to inventor?
Jef_E
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=17324828
I think you should benefit from following this and if there are more question please feel free to ask.
Inventor 2014 SP2
