Extended hardware Libraries
benboubaker
benboubaker
i am looking for more DIN and ISO hardware series than what is shown the Inventor 2019,
is it possible to buy them from Autodesk, or how to extend the current library copying existing ANSI hardware and change it for DIN or ISO.
Thank you,
bradeneuropeArthur
I am curious too.
What are you exactly searching for?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
benboubaker
I try to get more hardware with the correct DIN, ISO labels for the internal Part Number of the part Model when I create Bill Of Material, I have 2 choices:
1- I buy a bigger hardware library that includes DIN, ISO part numbers, Is Autodesk provide this?
2- or I Customize the current Library from Content Center, i will need the documentation to increase the current Library
