Exporting Parameters into Drawings
ASchlaack
Message 1 of 10
ASchlaack
I've got a rather large assembly which has parameters that drives all of the parts within it. In my .idw I need to be able to get the parameters from the .iam so I can fill out my iproperties correctly. How can I do this?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Replies (9)
Message 2 of 10
MechMachineMan
By accessing the model and then accessing the parameters through that...?
As simple as it sounds.
Also:
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 10
ASchlaack
That sounds simple, yes. But yet it doesn't work like that, I have tried everything from linking parameters to writing iLogic to autofill it.
Aaron Schlaack
Message 4 of 10
MechMachineMan
Have you correctly opened the assosciated models, and accessed the parameters in them through the API?
ie;
AssemblyComponentDefinition.Parameters
Justin K
Message 5 of 10
ASchlaack
Not using that code, how would I apply it?
Aaron Schlaack
Message 6 of 10
RodrigoEiras
Hi Aaron,
Another approach is to create an empty part that is linked to the Excel file and which is inserted in the assembly.
It must be defined in the assembly as a Phantom Part, as you don't want it to appear in the BOM.
Once you have that part you can easily access parameters from the assembly, and also from the drawings.
I hope it helps.
Rodrigo
Message 7 of 10
MechMachineMan
Not using what code and apply what?
What you said isn't very clear...
Justin K
Message 8 of 10
ASchlaack
I don;t understanding what you're saying to do in your last post.
Aaron Schlaack
Message 9 of 10
MechMachineMan
The only way I know is to write an iLogic program (using API help/vb.net) to open the assembly drawing and then pull/open a list of the parameters in a way that they are able to be formatted; ie an excel doc - so writing a program to open the linked excel doc like Rodrigo had mentioned would probably work best.
Otherwise, you could create new corresponding params in the .idw and write iLogic code to push them back to the assembly.
Justin K
Message 10 of 10
rjay75
Here's a method to use the parameters in an assembly to populate iProperties. If the parameters are numbers there's more you need to do to format the value. If you need to do that I give you a function to do that.
SyntaxEditor Code Snippet
IfActiveSheet.Sheet.DrawingViews.Count > 0 ThenSyntaxEditor Code Snippet
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
dwgParam = Parameter(modelName, "d0")
iProperties.Value("Project", "Part Number") = dwgParam
'set more iproperties
