Exporting Document Information to Excel - Using Variable in Formula
eric.frissell26WKQ
eric.frissell26WKQ
Hi, I've got a macro that I'm working on (which works well) except for 1 line which is trying to use an integer in a formula.  The line is
Range("Z2:Z & lastRow).Formula = "=ISNUMBER(SEARCH(-" & MatTypeIdentifier & ",RIGHT(B2,4)))"
I've seen people recommend double quotes but that results in a compile error in the Inventor VBA.  Anyone have any suggestions?  Seems there's gotta be a way which allows this to compile.
WCrihfield
Hi @eric.frissell26WKQ.
Just a couple quick questions/suggestions.
Was this:
supposed to be like this: (added an extra quotation mark ("))
Range("Z2:Z" & lastRow)
Also, to avoid having to use 'double quotation marks', you might be able to use Char(34), which represents the single quote mark character (Link1, Link2).
Wesley Crihfield
(Not an Autodesk Employee)
eric.frissell26WKQ
Thanks!  That's a great idea, I'll have to try it this way to see if that works otherwise it's going to be a mess of cells and concatanating.  You'd think there'd be a way to do it but it is what is.  And you're right about the correction, must have missed it
