Exporting a specific face as DXF with iLogic
talife4725
talife4725
I have to work with quite a lot of sheet metal at work and was looking into iLogic to export my sheet metal parts. I managed to adapt some iLogic code I found in here to our needs but I still have one issue and can't figure out how to solve it.
I often have to put 2 folded sheet metal parts together in a 45° angle which causes one problem: I need to export a specific face to get it laser cut.
The iLogic code I have here exports both sides of the flat pattern and all it's features. I would need it to export the face I define as face A.
Here is the code I'm using at the moment:
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
'Check that the active document is an assembly file
If oDoc.DocumentType <> kAssemblyDocumentObject Then
        MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
        Exit Sub
End If
'Get user input
RUsure = MessageBox.Show( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ", MessageBoxButtons.YesNo)
If RUsure <> vbYes Then Exit Sub
Dim oPath As String = ThisDoc.Path
'Get the DXF target folder path
Dim oFolder As String = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
        System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count)
For Each oRow As BOMRow In oBOMView.BOMRows
        Try
               Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
               Dim iDoc As Document = oCD.Document
               'SheetMetal parts only
               If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
               Dim iName As String = iDoc.FullFileName
               'Check that model is saved
               If iName = vbNullString Then Continue For
               iDoc = ThisApplication.Documents.Open(iName)
               oCD = iDoc.ComponentDefinition
               Dim oItem As String = oRow.ItemNumber
               Try
                       If Not oCD.HasFlatPattern Then
                               oCD.Unfold()
                       Else
                               oCD.FlatPattern.Edit()
                       End If
                       Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2018" _
                       + "&InteriorProfileLayer=IV_INTERIOR_PROFILES" _
                       + "&InteriorProfilesLayerColor=255;255;0" _
                       + "&OuterProfileLayer=IV_EXTERIOR_PROFILES" _
                      + "&InvisibleLayers=IV_TANGENT" _
                       + "&SimplifySplines=True" _
                       + "&BendLayerLineType=37633" _
                       + "&BendLayerColor=255;255;0" _
                       + "&BendUpLayerLineType=37633" _
                       + "&BendUpLayerColor=255;255;0" _
                       + "&BendDownLayerLineType=37633" _
                       + "&BendDownLayerColor=255;255;0" _
                       + "&FeatureProfilesLayerLineType=37633" _
                      + "&FeatureProfilesLayerColor=255;255;0" _
                       + "&FeatureProfilesUpLayerLineType=37633" _
                       + "&FeatureProfilesUpLayerColor=255;255;0" _
                       + "&FeatureProfilesDownLayerLineType=37633" _
                       + "&FeatureProfilesDownLayerColor=255;255;0"
                       Dim Nombre As String = oRow.ItemQuantity
                       Dim Matiere As String = ""
                       Dim Mat As String = iProperties.Material(iDoc.DisplayName)
                       If Mat = "Aluminium 6061"
                          Matiere = "alu"
                             ElseIf Mat = "Acier" Then
                                      Matiere = "ac"
                                 ElseIf Mat = "Acier inoxydable"
                                      Matiere = "nx"
                                 ElseIf Mat = "Acier, galvanisé"
                                      Matiere = "galva"
                             ElseIf Mat = "Acier inoxydable brossé"
                                      Matiere = "nxbrosse"
                                 ElseIf Mat = "Acier inoxydable 316L brossé"
                                      Matiere = "316Lbrosse"
                                 ElseIf Mat = "Acier inoxydable 316L"
                                      Matiere = "316L"
                                 Else
                                      Matiere = InputBox("La matière de cette pièce n'est pas définie, rajouter l'abréviation de la matière svp! ", "Matière manquante", "Indiquer la matière ici")
                       End If
                       Dim activepart As PartDocument = ThisApplication.ActiveDocument
                       Dim Sheetmetal As SheetMetalComponentDefinition = activepart.ComponentDefinition
                       Dim ThicknessSM As Parameter = Sheetmetal.Thickness
                       Dim Thickness As String = ThicknessSM.Value()*10
                       Dim ShortName As String = Left(iDoc.DisplayName, (InStrRev(iDoc.DisplayName, ".", -1, vbTextCompare) -1)) & "-" & Matiere & Thickness & "-" & Nombre & "x -" & ".dxf"
                       oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & ShortName)
                       oCD.FlatPattern.ExitEdit()
               Catch ex As Exception
                       MsgBox(ex.Message)
               End Try
               iDoc.Close(True)
        Catch
        End Try
Next
I'll put an example assembly and a few screenshots of what I mean.
For part 220168-10-02 I would need to export this face
but when I export it with the code above I get this:
which has those white lines which should straight up not be there and the yellow line should be in white
Our laser engraves yellows lines and dismisses red ones.
I'm still fairly new to iLogic, so I'm struggling quite a bit.
Thanks in advance to anyone who can help me.
blandb
In that image, it looks as if you have a beveled edge, can you re-do the cut operation to make sure that particular cut operation is normal to the face? I noticed that a lot of your cut operations in part 220168-10-02 are just extrude cut operations. If you use the sheet metal "Cut" command, you have the option to "Cut normal". Maybe that would help and your code would work as is?
Autodesk Certified Professional
