How can i use ilogic to change a parts assembly?
sevaslan
sevaslan
Hi. I have a assembly file which has a lot of iam files inside. I am trying to change the sub-assemblied parts flush using iLogic. I define some parameters as seen in screenshots but it doesn't change the flush when i try to change the number. For example i change "baski1" parameter from 1500 mm to 2000mm in the main assembly file. But it doesn't work . Could you help me please?
dalton98
If your trying to change the parameters in the sub assembly set it up like this
Parameter("BA Ic Dikme R:1", "baski1") = baski1
ThisApplication.ActiveDocument.Update
sevaslan
sevaslan_0-1650266965699.pngsevaslan_1-1650266982517.pngsevaslan_2-1650266998813.pngsevaslan_3-1650267048239.pngsevaslan_4-1650267100770.pngThank you, but i try it. I got this error message. Could you give any suggestions?
blandb
can you share the file?
Autodesk Certified Professional
sevaslan
I can't share the file because of privacy policies of my company. Is there anything we can do?
A.Acheson
The error suggest it cannot find the file/parameter. Can you add the parameter by capturing? Then run the sub assembly parameter through a message box to ensure you have access before trying to change it.
MessageBox.Show(Parameter("BA Ic Dikme R", "baski1"))
 Perhaps check also the value being supplied and ensure it works manually.
Regards
Alan
