- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. I have a assembly file which has a lot of iam files inside. I am trying to change the sub-assemblied parts flush using iLogic. I define some parameters as seen in screenshots but it doesn't change the flush when i try to change the number. For example i change "baski1" parameter from 1500 mm to 2000mm in the main assembly file. But it doesn't work . Could you help me please?
