Export step file with date in filename
info5RLCG
info5RLCG
I would like to write a macro, that exports the currently open file/assembly into a spt-file.
The file name should be with a date stamp and the filename, like this: 2023-10-02_filename.stp
I found following code in the VBA-samples of Inventor 2021, but I don't have a clue on how the saving with date stamp and filename could work.
Could you please give me a hint on this?
Thanks alot!
Best Regards
Martin
Public Sub ExportToSTEP()
    ' Get the STEP translator Add-In.
    Dim oSTEPTranslator As TranslatorAddIn
    Set oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If oSTEPTranslator Is Nothing Then
        MsgBox "Could not access STEP translator."
        Exit Sub
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = kFileBrowseIOMechanism
        Dim oData As DataMedium
        Set oData = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = "C:\temptest.stp"
        Call oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End Sub
bradeneuropeArthur
Dim dat As Date = Date.today
Set oData.FileName = "C:\_Export\temptest"& Replace( dat,"-","") &".stp"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
info5RLCG
Hi Arthur,
thanks for your reply, I really appreciate your effort.
It does not fully work and I get following error:
Translated to English, it says, that the number of arguments is not correct.
Could you please give me a tipp on how to solve this?
Thanks in advance!
bradeneuropeArthur
Use this in that case:
Dim n As Date = Date.Now
Dim y As String = n.Year.ToString
Dim m As String = n.Month.ToString
Dim d As String = n.Day
Dim dat As String = y +m+d
oData.FileName = "C:\_Export\temptest" & dat & ".stp"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
romu51
I've integrated this to one of my rules but the date displayed as 2024223...
how can i "force" the date to retain a 2 digit format to give me 20240223?
thanks.
