export sketch on a developed sheet metal with ilogic
m.nake
m.nake
I put a sketch on a developed sheet metal part. It is controlled by "Project geometry" and differs somewhat from the developed sheet metal part. With the right mouse button on the sketch I can export it as .dxf.
Now I would like to have the whole thing done via ilogic, but I just can't get to this sketch.
my attempt with:
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oCD As SheetMetalComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As Sketch = oCD.Sketches.Item("Skizze_Abwicklung")
If oSketch Is Nothing Then Exit Sub
oDoc.SelectSet.Select(oSketch)
is dismissed with the error message "wrong parameter".
Even in an .idw, I cannot display this sketch in isolation.
Does somebody has any idea?
Thanks in advance!
Martin
Martin
JhoelForshav
Hi @m.nake
Is your sketch sketched on the flat pattern? If it is and it's the first sketch on the flat pattern, try this 🙂
Dim strPath As String = ThisDoc.Path & "\"
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oFlatPattern As FlatPattern = oPartDoc.ComponentDefinition.FlatPattern
oFlatPattern.Sketches(1).DataIO.WriteDataToFile("DXF", strPath & oPartDoc.PropertySets. _
Item("Design Tracking Properties").Item("Part Number").Value & "_FlatPatternSketch.dxf")
You can change how you want to name the sketch. In this case it will be saved in the same folder as the part with the name partnumber_FlatPatternSketch.dxf
