set folder location
set folder location
jostroopers
set folder location
jostroopers
I want to save the parts in an assembly as a step file.
I want to store these step files in a specific folder at a location.
I have a code where the oPath was defined as :
oPath = ThisDoc.Path
but I want to change it to the folder: Z: \ Uni_Link \ Import \ Stepfiles
Can someone help me how to set that up correctly:
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
oPath = Z : "\" Uni_Link "\" Import "\" Stepfiles
'get STEP target folder path
oFolder = oPath & "\" & oAsmName & " STEP Files"
'Check for the step folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
jostroopers
Ok, i found it myself in another code on the forum.
oPath = "Z:\Uni_Link\Import\Stepfiles"
And I am not allowed to use spaces between " " otherwise I will get an error.
Mvg Jos
