Require a macro to open drawings and save, close, then move to next.
D_Kennington
Message 1 of 8
D_Kennington
Hello, In my company quite regularly we will have small changes to drawings (for example a change in issue date), but then this may apply to 200 drawings, which means opening all 200 drawings manually then saving the changes then closing the drawings every time this happens.
I was wondering if anyone has a macro, or could write a macro to open drawings, save changes, then close the drawing and move onto the next drawing in the folder until they're all done please?
Many thanks in advance.
Replies (7)
Message 2 of 8
I would do the following:
1) Create an EXTERNAL rule that will handle the updates
2) Set an  event trigger to run "On Open" for drawing files
3) Use Inventor's task scheduler. Create a task (an "Update" task should work), this will open each drawing in a folder in turn and update it using your rule.
Message 3 of 8
D_Kennington
Hi Clint,
Thanks for the reply, apologies but I'm not clued up enough on writing rules and creating tasks. could you elaborate please?
Message 4 of 8
ChristianAndersenIsmyname
This is something I've written for myself to open all part drawings from an assembly. Maybe this is something you can use.
            Dim invapp As Inventor.Application
            invapp = GetObject(, "Inventor.Application")
            Dim asmDoc As AssemblyDocument
            asmDoc = invapp.ActiveDocument
            If asmDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                For Each Doc In asmDoc.AllReferencedDocuments
                    If Doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                        Try
                            Dim drawing As String = Doc.FullFileName
                            drawing = drawing.Substring(0, drawing.Length - 3)
                            If System.IO.File.Exists(drawing & "idw") Then
                                invapp.Documents.Open(drawing & "idw")
                                'WRITE YOUR CODE HERE
                        Catch ex As Exception
                        End Try
                Next​
Message 5 of 8
I knocked a quick video together for you (apologies about the sound interference), hopefully, this will point you in the right direction.
https://screencast.autodesk.com/Embed/Timeline/8493311b-258a-43b3-846a-91991c5e8c1d
Code in the blog post can be found here: https://clintbrown.co.uk/2019/02/02/ilogic-title-block/
Message 6 of 8
D_Kennington
Clint, that is brilliant. Many thanks for your help!
Message 7 of 8
D_Kennington
Thanks for the reply! That's not what I was looking for but it's something I will definitely use. Thankyou.
Message 8 of 8
D_Kennington
Hi again Clint, you're solution works great, the only issue is that I've had a few errors pop up because my drawing doesn't have a view 1 (for example I've created it but then deleted it when I've made a mistake). Is there a bit of code that I could add at the start that would reset the view names so they start from view 1 again?
Many thanks
