Export results to Excel from Inventor vba
I have written a code in inventor vba and I need to export the results that I get from the msg box from inventor vba to Excel.
Can anybody tell me the basic code to export the same.?
MechMachineMan
What kind of message box? Do you just want it pasted in an excel cell? Have you taken a look at GoExcel commands?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Yes I want the results in the excel sheet in terms of rows and columns.
Also I want the sheet to get updated everytime the result changes. I dont have knowledge of GoExcel commands.
MechMachineMan
Google it.
Justin K
It would be helpul if you could share the code to export the results to excel.
Thanks.
MechMachineMan
The code I have will likely not have the same functionality you are looking
for, so you are better off searching the forums for Go Excel or googling.
Then when you actually have some code thrown down I would be more than
happy to help you debug it and we explain things then. Then you will
actually learn something.
I'm not a huge fan of doing people's jobs for them.
Justin K
