Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Export Prompt Sketch Symbol Text to a Excel
AMN3161
Message 1 of 13
AMN3161
So I have a prompt sketch symbol entry with one field used throughout a drawing with different texts but same sketch symbol name, does anyone have a rule to export all of that text to excel document? I am very unfamiliar with sketch prompt entries and not sure how to access its properties
thank you for any help
Replies (12)
Message 2 of 13
A.Acheson
You can look at the symbol object and get the displayed text
Syntax
SketchedSymbol.GetResultTextDefinitionText As TextBox ) As String
So if you loop through each Symbol in oActiveSheet.SketchedSymbols and select by name which one you want and retrieve text.
Regards
Alan
Message 3 of 13
AMN3161
Do you mind posting a quick example of how
"SketchedSymbol.GetResultTextDefinitionText As TextBox ) As String"
Would be used? I am very novice at this
Message 4 of 13
A.Acheson
Here is a sample.  Let me know if you understand this and or need more assistance.
Dim DrawDoc As DrawingDocument = ThisDoc.Document
Dim ActiveSht As Sheet = DrawDoc.ActiveSheet
For Each Sym As SketchedSymbol In ActiveSht.SketchedSymbols
	'Get text from first text box
	Dim TxtResult As String = Sym.GetResultText(Sym.Definition.Sketch.TextBoxes(1))
	MessageBox.Show(TxtResult, "Title")
Next
Regards
Alan
Message 5 of 13
AMN3161
Is the Sym where you call out the symbol name?
Message 6 of 13
J-Camper
@AMN3161,
@A.Achesonis showing how to loop through all symbols on  the active sheet.  If you want to filter only a specific symbol by name you can modify the rule like this:
Dim SketchedSymbolName As String = "Your Symbol Name"
	If Sym.Definition.Name <> SketchedSymbolName Then Continue For
Next
Message 7 of 13
AMN3161
I see, i understand now
thank you!
Message 8 of 13
A.Acheson
Once you declare an object as a SketchedSymbol you then have access to all its methods and properties, this becomes apparent when you get a drop down list  after you type " Sym" and start to use this object with "." . Here is the API help for SketchedSymbol. You will find "Name" under properties of Sketch Symbol.
Regards
Alan
Message 9 of 13
nnakka
How do i access prompted entry text box for all the symbols in one sheet and enter the values?
if i have 5 instances of same symbol(with prompted entry) in one sheet , i have to edit prompted entry 5 times to fill in values eg. 701,702,703,704,705,
Please help.
Thank you
Message 10 of 13
J-Camper
@nnakka,
You could do something like this:
Dim Instance As Integer = 1
Dim Prefix As String = String.Empty
	If Prefix = String.Empty Then Prefix = InputBox("Provide prefix for prompted entries in Symbol: " & SketchedSymbolName, "Prefix for Symbol", "Example_")
	'Set text from first text box
	Sym.SetPromptResultText(Sym.Definition.Sketch.TextBoxes(1), Prefix & Instance.ToString)
	Instance += 1
Next
This is pretty basic and could be refined to be more robust to handle finding the proper textbox by name, but I don't know any of your specific needs.
Let me know if you have any questions
Message 11 of 13
nnakka
Thank you so much . it works as i expected it to.
instance +1 works. only issue is if the number reaches 609 ,next one comes as 6010 as i started with 60
it gave 601,602.......609 and 6010.
How to change that to 610 ,611 automatic when i run the code?
appreciate the help.
Message 12 of 13
J-Camper
Try This:
	If Prefix = String.Empty Then Prefix = InputBox("Provide prefix for prompted entries in Symbol [leave room for 2 digit instances]: " & SketchedSymbolName, "Prefix for Symbol", "Example_")
	Dim InstanceAsString As String = Instance.ToString
	If InstanceAsString.Length = 1 Then InstanceAsString = "0" & Instance.ToString
	Sym.SetPromptResultText(Sym.Definition.Sketch.TextBoxes(1), Prefix & InstanceAsString)
	Instance += 1
Next
It should create 2 digit instances till 100, then it will be 3 digits.  Let me know if you have any questions
Message 13 of 13
nnakka
Just Brilliant... Works great.
Thanks again.
