export partslist to an text file with VBA
TechInventor20
Message 1 of 19
TechInventor20
I have an VBA code that put the whole partslist to Excel but excel takes to much time. The sollution is an Text file, but how can I make it in the way like down here....  1 to 13 is one row in the parts list (13 columns)
Replies (18)
Message 2 of 19
andrewiv
What if you used a csv file instead?  Then you could open it with excel or notepad.
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 19
A.Acheson
While a text file may be faster trying to modify to read like you want might be possible but might need some very custom code. What is your end goal in exporting the parts list?
You will need to have this post moved to the customization forum. If you post your VBA code there users can help you out with solutions and maybe optimize the code for speed.
Your exporting a parts list so data volume isn’t the issue I assume, so next thing is the excel interaction with inventor.
How quick does a new excel workbook open outside inventor? Should be 3-5 seconds on excel 2016.
Regards
Alan
Message 4 of 19
johnsonshiue
Hi! Regarding Excel being slow, you may want to looking to some change in settings. We have a user finding some Excel settings impacting the overall performance (see reply#7).
https://forums.autodesk.com/t5/inventor-forum/inserting-from-iassembly-extremely-long-time/td-p/9960...
It may or may not be related to your issue. I just want to share it with you.
Many thanks!
Software Test Engineer
Message 5 of 19
TechInventor20
@johnsonshiue  Thanks, I will look at that!
@A.Acheson / @andrewiv We have a program that keeps our warehouse up to date. but for that we need to put the parts in a program. Normally we would do that with a Macro (VBA) but since some of my colleagues have a new computer they can't connect with Excel anymore(via Inventor). But we have for Autocad also a rule that puts there parts list to a text file like I showed above and then our other program gets the values. So my first thought was to do the same because excel was very slow like 5-10 seconds. Now we try to get everything via csv or txt files. but for a txt file we all ready have a code that puts the values from the text file to our warehouse program.
I hope this answers your question
Message 6 of 19
TechInventor20
@andrewiv The problem is that some of our computers can't connect with Excel somehow. And we allready have a big part off the code that gets the date from a txt file and we like to do it this way. but if there is a way to re conect with excel that would be great!
below is a part of the code that we use. This is the part where the code gets the error.  when i define xls the value would be "Nothing" (Thats only on my colleagues computer not on mine, that works like a charm). if you know how to fix this that would also be great!
Message 7 of 19
bradeneuropeArthur
About how many parts are we talking in your partslist.
We have an export excel in no time for more then 300 rows in the partslist with 20 Columns.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 19
andrewiv
What version of Excel and Inventor are they using?  Have they tried running a repair on both the excel and inventor installs?
Andrew In’t Veld
Message 9 of 19
WCrihfield
Try this VBA code to write the parts list data out to a text file the way you want:
Sub PList_To_Txt_File()
    If ThisApplication.ActiveDocumentType <> kDrawingDocumentObject Then
        Call MsgBox("A drawing document must be active for this code to work.  Exiting.", , "")
        Exit Sub
    Dim oDDoc As DrawingDocument
    Set oDDoc = ThisApplication.ActiveDocument
    Dim oSheet As Inventor.Sheet
    Set oSheet = oDDoc.ActiveSheet
    If oSheet.PartsLists.Count = 0 Then
        Call MsgBox("There are no parts lists on the active sheet.  Exiting.", , "")
        Exit Sub
    Dim oPList As PartsList
    Set oPList = oSheet.PartsLists(1)
    Dim oFSO As New FileSystemObject
    Dim oTxtFile As TextStream
    Set oTxtFile = oFSO.CreateTextFile("C:/Temp/PartsList Data.txt")
    Dim oPLRow As PartsListRow
    Dim oPLCell As PartsListCell
    Dim oCell As Integer
    For Each oPLRow In oPList.PartsListRows
        For oCell = 1 To oPLRow.Count
            oTxtFile.WriteLine (oPLRow.Item(oCell).Value)
        Next
    Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 10 of 19
TechInventor20
I will ask the IT guy if  he would like to try that on the other computers!
Message 11 of 19
TechInventor20
I really hoped it would work but I get an error message... what to do about it?
Message 12 of 19
bradeneuropeArthur
You need the following reference in Vba:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 19
bradeneuropeArthur
I have also some piece of code to export the partslist to excel quickly.
I think this must also work quick for you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 19
TechInventor20
That is the excel version we use, but on my computer it works, but on my colleagues computer not.
This is where my colleagues get the error message
Message 15 of 19
bradeneuropeArthur
You should use late binding in this situations!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 19
TechInventor20
@bradeneuropeArthur
I don't really know what you mean, but at my PC i the value of xls is "Excel application" but at my Colleagues it said "Nothing" and afterwords it gets an error when it want to open the exel file (Because the value of xls is nothing).
Message 17 of 19
bradeneuropeArthur
Could you share the code, so that I can modify it for you?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 19
TechInventor20
This is de VBA code.
Option Explicit
Option Compare Text
Sub PartsnaarPDM()
Debug.Print "**** /PARTS LIST EXPORT START ****'"
' Make sure a drawing document is active.
Dim drawDoc As Document
Set drawDoc = ThisApplication.ActiveDocument
Dim activedrawing$
activedrawing$ = drawDoc.fullfilename
On Error Resume Next
'excel declaraties
Dim xls As Excel.Application
Dim wkb1 As Excel.Workbook
Dim wks1 As Excel.WorkSheet
Dim wks2 As Excel.WorkSheet
Dim wks3 As Excel.WorkSheet
'**** tekst file for debugging
'Bestandslocatie en bestandsnaam
Dim txtpath As String
txtpath = "C:\Temp\Inventor_debugfile.txt"
'tekst bestand leegmaken
Open txtpath For Output As #1: Close #1
'tekst toevoegen
Open txtpath For Append As #1
'Als je niet in de tekening omgeving zit
If Not (TypeOf drawDoc Is DrawingDocument) Then
MsgBox "A drawing must be active."
Exit Sub
' Make sure a parts list is selected.
Dim partList As PartsList 'object
Set partList = drawDoc.SelectSet.Item(1)
'als geen parts list geselecteerd is.
If Err.Number <> 0 Then
MsgBox ("Selecteer een parts list")
'error waarde wordt gereset zodat de code weer gebruikt kan worden verderop in de code
Err.Clear
Debug.Print "parts list selecteren"
Print #1, "parts list selecteren"
Set partList = ThisApplication.CommandManager.Pick(kDrawingPartsListFilter, "Selecteer parts list")
'Parts list moet in de juiste stijl staan 'PartsList.Style() As PartsListStyle
If partList.Style.Name = "KW Mono" Then
partList.Style = drawDoc.StylesManager.PartsListStyles.Item("KW_export_BOM_MONO")
Else
If partList.Style.Name <> "KW_export_BOM" Then
partList.Style = drawDoc.StylesManager.PartsListStyles.Item("KW_export_BOM")
'MsgBox ("Verander de parts list style naar:" & vbNewLine & "KW_export_BOM" & vbNewLine & "Annotate -> Format")
'Exit Sub
'Bij fout
MsgBox ("FOUT bij parts list selectie")
If Not wkb1 Is Nothing Then wkb1.Close False
If Not xls Is Nothing Then xls.Quit
Err.Clear
End
Exit Sub
Set xls = GetObject(, "Excel.Application")
Set xls = New Excel.Application
Set wkb1 = xls.Workbooks.Open("c:\pdm2012\inventor2PDM.xls")
Set wks1 = wkb1.Worksheets(1)
Set wks2 = wkb1.Worksheets(2)
Set wks3 = wkb1.Worksheets(3)
Debug.Print "sheet1 = " & wks1.Name
Debug.Print "sheet2 = " & wks2.Name
Debug.Print "sheet3 = " & wks3.Name
Print #1, "sheet1 = " & wks1.Name
Print #1, "sheet2 = " & wks2.Name
Print #1, "sheet3 = " & wks3.Name
'Als excel bestand niet bestaat
MsgBox ("1) Excel tabel inventor2PDM.xls is niet gevonden")
Err.Clear
End
Exit Sub
Debug.Print "Parts list kopiëren"
Print #1, "Parts list kopiëren"
Dim Counter As Integer
Counter = 1
'Activate the destination worksheet
Debug.Print "worksheet 2 activeren en leeg maken"
Print #1, "worksheet 2 activeren en leeg maken"
wks2.Cells.Clear
Debug.Print " Stuklijst exporteren"
Print #1, " Stuklijst exporteren"
'Starting cell position on the Excel sheet
Dim iRowStart As Integer: iRowStart = 1
Dim iColStart As Integer: iColStart = 1
'Export headers
Dim iRow As Integer: iRow = iRowStart
Dim iCol As Integer: iCol = iColStart
Dim oCol As PartsListColumn
For Each oCol In partList.PartsListColumns
wks2.Cells(iRow, iCol).Value = oCol.Title
iCol = iCol + 1
Next
iRow = iRow + 1
' Export content
Dim oRow As PartsListRow
For Each oRow In partList.PartsListRows
If oRow.Visible Then
iCol = iColStart
Dim oCell As PartsListCell
For Each oCell In oRow
wks2.Cells(iRow, iCol).Value = oCell.Value
iCol = iCol + 1
Next
iRow = iRow + 1
Next
Debug.Print " Stuklijst in Excel geplaatst"
Print #1, " Stuklijst in Excel geplaatst"
'Fout tijdens exporteren
MsgBox ("Fout tijdens exporteren")
Err.Clear
End
Exit Sub
MsgBox ("Fout met Excel en stuklijst")
'ActiveWorkbook.Close savechanges:=False
Err.Clear
End
Exit Sub
'Besteld en toeleveringen verwijderen uit stuklijst
'Alleen voorraad in stuklijst
Dim i As Integer
Dim j As Integer
Debug.Print "Alleen voorraadartikelen in stuklijst"
Print #1, "Alleen voorraadartikelen in stuklijst"
Dim LastRow1 As Long
With wks2 'Laatste rij vinden
LastRow1 = .Cells(.Rows.count, "A").End(xlUp).Row
Debug.Print "Lastrow1 = " & LastRow1
Print #1, "Lastrow1 = " & LastRow1
End With
For j = 2 To LastRow1
'Artikelnummer in hoofdletters anders leest PDM ze niet uit.
wks2.Cells(j, "C").Value = UCase(wks2.Cells(j, "C").Value)
If wks2.Cells(j, "M") <> "M" Then
Debug.Print " POS: " & wks2.Cells(j, "A") & " - is Besteldeel, regel verwijderen"
Print #1, " POS: " & wks2.Cells(j, "A") & " - is Besteldeel, regel verwijderen"
wks2.Cells(j, "M").EntireRow.ClearContents
'wks2.Cells(j, "M").EntireRow.Delete xlUp
Else
Debug.Print " POS: " & wks2.Cells(j, "A") & " - is voorraaddeel"
Print #1, " POS: " & wks2.Cells(j, "A") & " - is voorraaddeel"
If wks2.Cells(j, "C") = "" And wks2.Cells(j, "M") <> "" Then
Debug.Print " POS: " & wks2.Cells(j, "A") & " - artikel is niet ingevuld"
Print #1, " POS: " & wks2.Cells(j, "A") & " - artikel is niet ingevuld"
MsgBox "Artikelnummer is leeg, deze moet ingevuld zijn bij voorraaddeel" & vbNewLine & "POS: " & wks2.Cells(j, "A") & vbNewLine & "Parts list niet geëxporteerd"
Exit Sub
Next j
'Bij fout
MsgBox ("Fout bij verwijderen bestelde artikelen")
Err.Clear
End
Exit Sub
End With
'20x300 naar LB=0020x0300 voor export naar PDM
Debug.Print "ilogic regel uitvoeren: afmetingen_format "
Print #1, "ilogic regel uitvoeren: afmetingen_format "
'Sub Afmetingen_format()
'On Error Resume Next
Dim continue_rule As String
continue_rule = "0"
MsgBox ("Fout bij openen Excel workbook, inventor2PDM.xlsx")
continue_rule = "2"
Err.Clear
Exit Sub
'******************** afmetingen format
Dim x As Long, LastRow As Long
Debug.Print " Unit in m of in m2, controle"
Print #1, " Unit in m of in m2, controle"
End With
Dim foutmelding As String
foutmelding = "0"
'Hier code plaatsen die uitgevoerd dient te worden bij een fout
continue_rule = "2"
MsgBox ("Fout bij afmetingen formatteren" & vbNewLine & "POS: " & wks2.Cells(j, "A"))
Err.Clear
'Exit Sub
Dim LString As String
Dim LArray() As String
'Unit invullen
If wks2.Cells(j, "L") = "" Then 'Leeg
Debug.Print " 01-Unit moet ingevuld zijn met m of m2 - " & "POS:" & wks2.Cells(j, "A") & vbNewLine; "/wordt nu automatisch zelf ingevuld"
Print #1, " 01-Unit moet ingevuld zijn met m of m2 - " & "POS:" & wks2.Cells(j, "A") & vbNewLine; "/wordt nu automatisch zelf ingevuld"
Dim celltxt As String
celltxt = wks2.Cells(j, "C")
Debug.Print " celltxt = " & celltxt
Print #1, " celltxt = " & celltxt
If InStr(1, celltxt, "2P") Then
wks2.Cells(j, "L") = "M2"
Debug.Print " M2 ingevuld als unit"
Print #1, " M2 ingevuld als unit"
ElseIf wks2.Cells(j, "C") <> "" And wks2.Cells(j, "A") <> "" And wks2.Cells(j, "E") <> "" Then
wks2.Cells(j, "L") = "M"
Debug.Print " M ingevuld als unit"
Print #1, " M ingevuld als unit"
ElseIf wks2.Cells(j, "C") <> "" And wks2.Cells(j, "A") <> "" And wks2.Cells(j, "E") = "" Then
wks2.Cells(j, "L") = "ST"
Debug.Print " ST ingevuld als unit"
Print #1, " ST ingevuld als unit"
If wks2.Cells(j, "L") = "M" Then 'Meters gevonden
Debug.Print "POS: " & wks2.Cells(j, "A") & " - Buis/koker"
Print #1, "POS: " & wks2.Cells(j, "A") & " - Buis/koker"
LString = wks2.Cells(j, "E") 'E is afmeting
If LString = "" Then
MsgBox ("POS: " & wks2.Cells(j, "A") & "Afmetingen moeten ingevuld zijn ")
foutmelding = "1"
LString = Replace(LString, " ", "") 'spaties weghalen
wks2.Cells(j, "E") = LString
Dim IsAlphabet As Boolean
Dim chkChar As String
'Dim Counter As Integer
Dim MyString As String
MyString = wks2.Cells(j, "E") 'E is afmeting
MyString = UCase(MyString) 'alles in hoofdletters
Debug.Print " Check op geen letters in de afmeting met unit: M, staan."
Print #1, " Check op geen letters in de afmeting met unit: M, staan."
For Counter = 1 To Len(MyString)
chkChar = Mid(MyString, Counter, 1)
IsAlphabet = Asc(chkChar) > 64 And Asc(chkChar) < 91
If IsAlphabet = True Then
MsgBox "POS:" & wks2.Cells(j, "A") & "Er mogen geen letters in afmeting met unit: M staan" & vbNewLine & " Parts list niet geëxporteerd"
continue_rule = "2"
Exit Sub
Next
ElseIf wks2.Cells(j, "L") = "M2" Then 'Meter2 gevonden
Debug.Print "POS " & wks2.Cells(j, "A") & " - Plaatwerk"
Debug.Print " Afmetingen kolom = E" 'E is afmeting
Print #1, " POS " & wks2.Cells(j, "A") & " - Plaatwerk"
Print #1, " Afmetingen kolom = E" 'E is afmeting
foutmelding = "1"
LString = Replace(LString, "LB=", "")
If InStr(1, LString, "x") Then
LArray = Split(LString, "x") 'zoekstring
Debug.Print " bevat kleine x"
Print #1, " bevat kleine x"
ElseIf InStr(1, LString, "X") Then
LArray = Split(LString, "X") 'zoekstring
Debug.Print " bevat grote X"
Print #1, " bevat grote X"
Else
Debug.Print " fout bij afmetingen plaat"
Print #1, " fout bij afmetingen plaat"
MsgBox ("POS: " & wks2.Cells(j, "A") & " Fout bij afmetingen Plaat")
Exit Sub
Debug.Print " van 500x500 naar LB=0500x0500"
Print #1, " van 500x500 naar LB=0500x0500"
'van 500x500 naar LB=0500x0500
Dim lengte1 As Double
Dim breedte1 As Double
lengte1 = LArray(0)
breedte1 = LArray(1)
Dim lengte As String
Dim breedte As String
lengte = Format(lengte1, "0000")
Debug.Print " lengte = " & lengte
Print #1, " lengte = " & lengte
breedte = Format(breedte1, "0000")
Debug.Print " breedte = " & breedte
Debug.Print " LB=" & lengte & "X" & breedte
Print #1, " breedte = " & breedte
Print #1, " LB=" & lengte & "X" & breedte
wks2.Cells(j, "E") = "LB=" & lengte & "X" & breedte
'MsgBox Cells(j, "E")
MsgBox ("Fout bij afmetingen omzetten van 500x500 naar LB=0500x0500" & vbNewLine & "POS: " & wks2.Cells(j, "A"))
continue_rule = "2"
Err.Clear
Exit Sub
Debug.Print " volgende POS"
Next j
If foutmelding = "1" Then
MsgBox "Parts list niet geëxporteerd"
Close #1
Exit Sub
MsgBox ("Algemene Fout")
continue_rule = "2"
Err.Clear
Exit Sub
'einde afmetingen format
'START Lege rijen verwijderen op basis van niet ingevulde positienummers
End With
For j = LastRow1 To 1 Step -1
If wks2.Cells(j, 1) = "" Then
wks2.Rows(j).EntireRow.Delete
Debug.Print "Rij is leeg dus verwijderen"
Print #1, "Rij is leeg dus verwijderen"
Next
'EINDE Lege rijen verwijderen op basis van niet ingevulde positienummers
'als er eerder een fout gevonden is dan wordt dat nu weergegeven
Debug.Print " continue_rule is: " & continue_rule
Debug.Print " **einde - afmetingen format"
Print #1, " continue_rule is: " & continue_rule
Print #1, " **einde - afmetingen format"
If continue_rule = "2" Then
Debug.Print "continue_rule=2 ERROR"
Print #1, "continue_rule=2 ERROR"
Exit Sub
MsgBox ("Fout bij afmetingen_format")
Err.Clear
Exit Sub
'*** Uitleg
'Dit stukje code zorgt ervoor dat de gegevens van een bepaalde kolom op sheet2
'gekopieërd worden naar een bepaalde kolom op sheet1
'*** Declare Variables ***
Dim lLastRow As Long
Dim destRng As Range
'worksheet schoon maken en vervolgens de koppen kopieren van de BOM
wks1.Cells.Clear
wks3.Range("A1:N1").Copy Destination:=wks1.Range("A1")
Dim LastCol2 As Integer
LastCol2 = .Cells(1, .Columns.count).End(xlToLeft).Column
Debug.Print "LastCol2 = " & LastCol2
Print #1, "LastCol2 = " & LastCol2
End With
'wat in de cases staat daar wordt op gezocht en geplakt
Dim LastCol1 As Integer
With wks1 'Laatste rij vinden
LastCol1 = .Cells(1, .Columns.count).End(xlToLeft).Column
Debug.Print "LastCol1 = " & LastCol1
Print #1, "LastCol1 = " & LastCol1
End With
i = 1
j = 1
Dim columntitle2 As String
Dim columntitle1 As String
For i = 1 To LastCol2
columntitle2 = wks2.Cells(1, i).Value
For j = 1 To LastCol1
columntitle1 = wks1.Cells(1, j).Value
If columntitle2 = columntitle1 Then
wks2.Columns(i).Copy Destination:=wks1.Columns(j)
Debug.Print columntitle2
Print #1, columntitle2
Next
Next
MsgBox ("Fout bij kopiëren kolommen; check VBA en Excel")
Err.Clear
End
Exit Sub
'BOM 3 regels omlaag verplaatsen
'zodat het 3 regels lager op BOM word geplaatst
wks1.Rows(2).Insert shift:=xlShiftDown
'***************** Omschrijving/datum/gebruiker in stuklijst kop zetten
'declareren
Dim Omschrijving_str$
Dim Datum$
Dim Projectleider$
'tekeningnummer en omschrijving
' Get the active document.
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
' Get the custom property set.
Dim CustomPropSet As PropertySet
Set CustomPropSet = doc.PropertySets.Item( _
"Inventor User Defined Properties")
' Get the property named "tekeningnummer".
Dim customProp As Property
Set customProp = CustomPropSet.Item("02-Tekeningnummer")
Dim customProp2 As Property
Set customProp2 = CustomPropSet.Item("02-Omschrijving")
MsgBox ("02-Tekeningnummer & 02-Omschrijving niet gevonden")
Err.Clear
End
Exit Sub
' Display the value of the iProperty.
Dim Tekeningnummer$
Tekeningnummer$ = customProp.Value
Debug.Print "tekeningnummer = " & Tekeningnummer$
Print #1, "tekeningnummer = " & Tekeningnummer$
Dim dwgOmschrijving$
dwgOmschrijving$ = customProp2.Value
Debug.Print "dwgOmschrijving = " & dwgOmschrijving$
Print #1, "dwgOmschrijving = " & dwgOmschrijving$
'Omschrijving invullen
Omschrijving_str$ = Tekeningnummer$
wks3.Cells(2, 4) = Omschrijving_str$ & " - " & dwgOmschrijving$
'datum plakken
Datum$ = Format(Now(), "dd-mm-yyyy")
wks3.Cells(4, 4) = "Datum: " & Datum$
'gebruiker plakken
Projectleider$ = ThisApplication.GeneralOptions.UserName
wks3.Cells(3, 4) = "Projectleider: " & Projectleider$
Debug.Print "layout en tekst kopiëren"
Print #1, "layout en tekst kopiëren"
'layout&koptekst kopieren van bom3 naar bom
wks3.Range("A1:L4").Copy Destination:=wks1.Range("A1")
'AutoFit All Columns on Worksheet
wks1.Cells.EntireColumn.AutoFit
wks1.Cells.WrapText = False
'excel bestand saven/sluiten
wkb1.Close True
Set wks1 = Nothing
Set wks2 = Nothing
Set wks3 = Nothing
Set wkb1 = Nothing
xls.Quit
Set xls = Nothing
'partList.Style = drawDoc.StylesManager.PartsListStyles.Item("KW")
MsgBox "Stuklijst naar Excel geëxporteerd" & vbNewLine & "Wacht op PDM pop-up" & vbNewLine & "druk op OK"
'in pdm zetten
'START.exe uitvoeren en wachten totdat deze compleet uitgevoerd is
Dim wsh As Object
Set wsh = VBA.CreateObject("WScript.Shell")
Dim waitOnReturn As Boolean: waitOnReturn = True
Dim windowStyle As Integer: windowStyle = 1
wsh.Run "c:\pdm2012\mcadp418.exe", windowStyle, waitOnReturn
'EINDE .exe uitvoeren en wachten totdat deze compleet uitgevoerd is
MsgBox ("Fout bij PDM module")
Err.Clear
End
Exit Sub
Print #1, "**** /PARTS LIST EXPORT KLAAR ****'"
Close #1 'debug tekstfile sluiten
Debug.Print "**** /PARTS LIST EXPORT KLAAR ****'"
Set drawDoc = ThisApplication.Documents.Open(activedrawing$, True)
'Test
Debug.Print
Dim RuleName As String
'********************************| Locatie van de regel |Naam van regel|
RuleName = Inventor_zoeklocatie & "AuTTeK\TDV\Undo.iLogicVb" 'ilogic regel
'***** Externe regel uitvoeren*****
Dim Fname3 As String
Dim RuleName2 As String
Fname3 = ThisApplication.ActiveDocument.fullfilename
If Fname3 = "" Then
MsgBox "Document eerst opslaan"
Exit Sub
Debug.Print Fname3
Call RunRule1(Fname3, RuleName)
'***** updaten *****
Line_update:
ThisApplication.ActiveView.Update
ThisApplication.ActiveDocument.Update
Debug.Print "*Reset k factor* EIND!"
End Sub
Message 19 of 19
TechInventor20
I have found a code to put it to a text file.
Many thanks again for trying to explaining to me @bradeneuropeArthur
