Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Export main assembly to RFA file using iLogic
frahaman7SKBG
frahaman7SKBG
Looking for help with iLogic to export main iam assembly to RFA.
Found this thread, but this code exports all the individual components and not the whole assembly.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/rfa-export/m-p/9783828#M116607
WCrihfield
Hi @frahaman7SKBG.  I haven't tested this yet, so be careful, because I don't use BIM stuff.  But in theory the following simpler iLogic code should work for you if you just want to export the main assembly.  It simply captures the currently 'active' assembly document, then uses the same path and file name as that assembly, but with the ".rfa" file extension when exporting the rfa file.  If you need to change the path or file name further, you can change the line defining oFFN, or use multiple more lines to manipulate the string (text).
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
	Exit Sub
'gets the 'active' assembly document
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
'same path & file name as active assembly, but with ".rfa" file extension
Dim oFFN As String = System.IO.Path.ChangeExtension(oADoc.FullFileName, ".rfa")
'export
oADef.BIMComponent.ExportBuildingComponent(oFFN)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
ehuliganga
This is great, would you be able to do this with automation for batch updating OmniClass and Family Type Names of models and assemblies?
