Parts List Table Title Automation
MikeKovacik4928
Advisor Advisor
Message 1 of 27
MikeKovacik4928
Hi all
I like to add the part number & description of my parent sub assy to the title of the
part list table to make it easier for the person reading the drawing to link it to the correct view.
I do this by entering it in manually in the Parts List Table Layout, Heading and Table Settings, Title
It would be nice if you could link iproperties to this title box, so that you could set up a title
for your parts list to appear automatically and the same for all your title blocks,
instead of typing it in manually each time.
See attached PDF for screenshots of what I am talking about.
IS THERE A WAY OF DOING THIS (WITHOUT USING ILOGIC) ?
(I have seen similar posts where this has been solved by  ilogic)
Michael Kovacik
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (26)
Message 2 of 27
mcgyvr
(Impossible only means you haven't used ilogic yet?) Smiley Very Happy
Whats wrong with using ilogic?
Its perfect for this type of customization..
Message 3 of 27
MikeKovacik4928
Nothing at all, if that is the way it has to be done.
I am new on ilogic, but am more than willing to learn.
How is it done?
Lead the way
Mike
Message 4 of 27
MikeKovacik4928
Any takers?
I still want to implement this.
Like I said I am very willing to use ilogic,
but need help as I am a newbie with ilogic
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
Message 5 of 27
MikeKovacik4928
okay
I guess I will carry on doing this manually for the time being!
Mike
Message 6 of 27
matt_jlt
I wrote the following examples below in VBA and the last one is converted to iLogic / VB.net. This is most of the work done for you. now all you need to do is get the part number / property of whatever sub occurrence you were referring to and insert the text where it shows in the below code.
I would have tried to work that out but It was not clear on what assembly you were trying to pull the iproperty from.
Hope it helps, Matt.
Public Sub ChangeAllPartsLists_AllSheets()
    ' Define and get drawing document
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Define sheet and parts list
    Dim oSheet As Sheet
    Dim oPL As PartsList
    ' Iterate through all sheets in the active document
    For Each oSheet In oDoc.Sheets
        ' Iterate through all parts lists in each sheet
        For Each oPL In oSheet.PartsLists
            ' Change the title of the parts list to a string
            oPL.Title = "TEST TITLE HERE"
        Next
    Next
End Sub
Public Sub ChangeAllPartsLists_ActiveSheet()
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    ' This could be used instead of the For Each loop if there is only ever one parts list on a sheet.
    'Set oPL = oSheet.PartsLists.Item(1)
    Next
End Sub
' iLogic Rule to change the title text of all parts lists
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
For Each oSheet As Sheet In oDoc.Sheets
	For Each oPL As PartsList In oSheet.PartsLists
		oPL.Title = "ILOGIC TEST TITLE HERE"
	Next
Next
Message 7 of 27
MikeKovacik4928
Thank you very much for that.
I will try it out at home, as soon as I can, and get back to you.
I do not have time at work, nor would I be allowed to do it there either.
All of my correspondence with the forums is done on my own time,
and with my own licensed software.
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
(personal licensed copy)
Message 8 of 27
MikeKovacik4928
Fantastic!
NOW
WHAT DO I ENTER INTO THE ILOGIC INSTEAD OF
"ILOGIC TEST TITLE HERE" TO GET THE IPROPERTIES
FROM THE IAM.
IN OTHER WORDS I WANT TO USE THE IPROPERTY
VALUE FROM THE ASSEMBLY, RATHER THAN THE TEXT STRING.
See attached pdf for full description of what I want to do.
Michael Kovacik
-Cad (28 yrs)
--Cadkey (4 yrs)
--Inventor (4 yrs)
(own personal licensed copy)
Message 9 of 27
matt_jlt
' iLogic rule to get the iproperties
Define Variables Dim oSheet As Sheet = ThisDrawing.Document.Sheets.Item(1) ' Check if there are any views on the sheet If oSheet.DrawingViews.Count = 0 Then Exit Sub ' Define Variables Dim oDoc As Document = ThisDrawing.ModelDocument Dim oView As DrawingView = oSheet.DrawingViews.Item(1) ' Get Description from model Dim strDescr As String = oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value Dim strPartNo As String = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
oPL.Title = strPartNo & strDescr & "Anytext you want"
Next
Next
Message 10 of 27
MikeKovacik4928
Have quickly tried this out during my lunch hour.
Doesn't seem to work.
Get error message.
See jpg's attached.
Mike
Message 11 of 27
matt_jlt
That would be because i just did a copy paste to put the two segments together. The error message was stating that there were two variables with the same name. Just had to change the second oDoc to something different which I chose oDrgDoc. I haven't tested it but it should work.
' Define Variables
' Define Variables
Dim oDrgDoc As DrawingDocument = ThisApplication.ActiveDocument
For Each oSheet As Sheet In oDrgDoc .Sheets
 Next
Next
Message 12 of 27
dgreatice
Dim invApp As Inventor.Application
invApp = ThisApplication
If invApp.ActiveDocumentType = kDrawingDocumentObject Then
Else
MsgBox ("You can access in this rule!")
Exit Sub
Dim oDWGDoc As DrawingDocument
oDWGDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oPartlist As PartsList
Dim PartNo As String
Dim Desc As String
Dim Mass as String
Dim oModelDoc As Document
Dim oAssyDocType As AssemblyDocument
Dim oPartDocType As PartDocument
For Each oSheet In oDWGDoc.Sheets
For Each oPartlist In oSheet.PartsLists
oModelDoc = oPartlist.ReferencedDocumentDescriptor.ReferencedDocument '(Get Data From Part List Document)
PartNo = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Desc = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
If oModeldoc.documenttype = kAssemblyDocumentObject Then
oAssyDocType = oModelDoc
PropMass = Round(oAssyDocType.ComponentDefinition.MassProperties.Mass, 2) ' get mass
Else
oPartDocType = oModelDoc
PropMass = Round(oPartDocType.ComponentDefinition.MassProperties.Mass, 2) ' get mass
oPartlist.Title = "PART LIST; " & PartNo & " ; " & Desc & " ; MASS - " & PropMass & " Kg"
Next
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 13 of 27
dgreatice
You can use this code even no base view (only partlist)
Message 14 of 27
MikeKovacik4928
Still doesn't work
See attached message
Message 15 of 27
dgreatice
Did you try my code mike?
Message 16 of 27
MikeKovacik4928
Perfect Thanks
Mike
Message 17 of 27
MikeKovacik4928
Thanks for that ilogic programme. It worked perfectly.
Could you remove the mass part from your programme.
or tell me what to remove from the ilogic programme,
I don't want the mass to appear in the title block title.
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
Message 18 of 27
dgreatice
It simple.
At row 3 from bottom. Type ' after Desc
It seem like this:
oPartlist.Title = "PART LIST; " & PartNo & " ; " & Desc ' & " ; MASS - " & PropMass & " Kg"
For the futher if you want to activated mass value, just delete '
Message 19 of 27
MikeKovacik4928
Fantastic
I think I must start learning ilogic as one of my next tasks!!
Mike
Message 20 of 27
cadman777
dgreatice,
Thanx for posting your elegant code.
I used it and it works like a charm.
Thanx!
There is one challenge, however, which I can't figure out after many hours of trying.
If you (or anybody else who knows how to code) would please help me?
Challenge: The macro fails when the iProperty does not exist.
To try to solve this, I added some of Curtis' code (adds iProperties to a part or assembly). His code works great as a stand-alone macro, but I can't figure out how to get his code to act on the assembly which the Parts List is referencing.
When running this macro from the drawing file, would you please help me know how to reference the assembly file?
I think the relevant line is this:
oModelDoc = oPartlist.ReferencedDocumentDescriptor.ReferencedDocument ' (Get Data From Part List Document)
I've annotated it with a note typed in all uncials.
Thanx for any input you may be able to give!
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
