Export Flatpattern to DXF from Assembly. Filenaming.
Jesper_S
Message 1 of 11
Jesper_S
Hi.
I got an working code for this already but I am wondering if its possible to make some changes.
Instead of getting the filename for the .DXF from the .ipt itself, i would like to get the filename from
the Main Assembly and if its possible, itemnumber from the BOM for the part that's exported.
Example. Main Assembly name is ABCDEFG and i got a sheetmetal part with Itemnumber 8.
I want the filename to be  "ABCDEFG-8"
This code will be run when the design is finished and approved for manufacturing so there will be no renumbering of the BOM.
Running IV 2015.
Present Code.
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
	Return
	Else
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
		For Each oRefDoc In oRefDocs
			iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    		'check that model is saved
			If(System.IO.File.Exists(iptPathName)) Then
                Dim oDrawDoc As PartDocument
                oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
            	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
				Try
                	'Set the DXF target file name
                	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
					Dim oCompDef As SheetMetalComponentDefinition
					oCompDef = oDrawDoc.ComponentDefinition
					If oCompDef.HasFlatPattern = False Then
						oCompDef.Unfold
					Else
   						oCompDef.FlatPattern.Edit
					Dim sOut As String
					sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
					oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
					'just for check its works coretcly
					'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
					'MessageBox.Show(i,"title",MessageBoxButtons.OK)
					'If i=2 Then
						'Exit Sub
					'End If
					oCompDef.FlatPattern.ExitEdit
				Catch
				End Try
				oDrawDoc.Close
			Else
		Next
If more info is needed, ask me.
Thanks in advance.
//Jesper
Replies (10)
Message 2 of 11
Owner2229
Something like this?
'Define the active document as an assembly file
Dim oDoc As Document = ThisApplication.ActiveDocument
'Check that the active document is an assembly file
If oDoc.DocumentType <> kAssemblyDocumentObject Then
	Exit Sub
'Get user input
& vbLf & " " _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ", MessageBoxButtons.YesNo)
If RUsure <> vbYes Then Exit Sub
Dim oAsmName As String = Left(oDoc.DisplayName, Len(oDoc.DisplayName) - 4)
Dim oPath As String = ThisDoc.Path
'Get the DXF target folder path
Dim oFolder As String = oPath & "\" & oAsmName & " DXF Files"
Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
'You'll have to play with this to get the BOM you want. Try 1, 2, 3 or "Structured"
Dim oBOMView As BOMView = oBOM.BOMViews.Item(2)
For Each oRow As BOMRow In oBOMView.BOMRows
	Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
	Dim iDoc As Document = oCD.Document
	'SheetMetal parts only
	If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
	Dim iName As String = iDoc.FullFileName
	If iName = vbNullString Then Continue For
	iDoc = ThisApplication.Documents.Open(iName)
	oCD = iDoc.ComponentDefinition
	Dim oItem As String = oRow.ItemNumber
	Try
		If Not oCD.HasFlatPattern Then
			oCD.Unfold()
		Else
			oCD.FlatPattern.Edit()
		Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
		oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & oAsmName & "-" & oItem & ".dxf")
		oCD.FlatPattern.ExitEdit()
	Catch ex As Exception
		MsgBox(ex.Message)
	End Try
	iDoc.Close(True)
Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 11
Jesper_S
Hi.
Thanks for answering.
Got this when i tried the code.
Error in rule: Rule3, in document: 66430-300.iam
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Forum copy error or something else?
//Jesper
Message 4 of 11
Owner2229
I'm not sure what might be causing the issue, but you can try it with some error handling:
Red highlighted is what I've changed.
Also you can try to place this "MsgBox(1)" in the code (and move it) to see how far can the rule get without crashing and this way find the line with the error.
	Exit Sub
'Get user input
& vbLf & " " _
Dim oBOMView As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count) For Each oRow As BOMRow In oBOMView.BOMRows Try Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1) Dim iDoc As Document = oCD.Document 'SheetMetal parts only If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For Dim iName As String = iDoc.FullFileName 'Check that model is saved If iName = vbNullString Then Continue For iDoc = ThisApplication.Documents.Open(iName) oCD = iDoc.ComponentDefinition Dim oItem As String = oRow.ItemNumber Try If Not oCD.HasFlatPattern Then oCD.Unfold() Else oCD.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE" oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & oAsmName & "-" & oItem & ".dxf") oCD.FlatPattern.ExitEdit() Catch ex As Exception MsgBox(ex.Message) End Try iDoc.Close(True) Catch End Try Next
Mike
Message 5 of 11
Jesper_S
The line marked as red. If i move the messagebox above it, the message appears.
	Exit Sub
'Get user input
& vbLf & " " _
MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Try
	Try
			oCD.Unfold()
		Else
		MsgBox(ex.Message)
	End Try
	iDoc.Close(True)
Catch
End Try
Next
//Jesper
Message 6 of 11
Jesper_S
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
	Exit Sub
'Get user input
& vbLf & " " _
'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
Try
	Try
			oCD.Unfold()
		Else
		MsgBox(ex.Message)
	End Try
	iDoc.Close(True)
Catch
End Try
Next
Now it works. I changed the parts in red.
Thansk alot for your help.
//Jesper
Message 7 of 11
Owner2229
That doesn't make any sense... But if it works ¯\_(ツ)_/¯
Mike
Message 8 of 11
MechMachineMan
I think I've run into cases before when it seems to bug out and the functions won't take without having the ComponentDefinition completely declared (ie; "As AssemblyComponentDefinition" following an "As AssemblyDocument"), but that restarting inventor would fix it as well, so it was a session based thing. Maybe something similar here?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 9 of 11
Owner2229
Might be as I've tested the code and it worked for me (as I've posted it).
Mike
Message 10 of 11
Jesper_S
Hi.
Correct, I restarted Inventor and @Owner2229 :s code works just fine.
//Jesper
Message 11 of 11
cadman777
Dear Owner,
Thanx for posting this 'code'.
I want to write my own, but maybe can use yours and adapt it to my needs.
So would you be so kind as to explain where you get the BOM 'Item Number', and where you insert it into the file name?
Also, how would you change that to be the 'Stock Number' instead of the 'Item Number'?
FYI:
I don't know VB nor do I know iLogic.
I actually HATE programming, but by force of need, I have to learn it AGAIN.
I just want to know what these things mean.
I need a book that defines the variables and the syntax, and also a book to look up the various elements (iProps, Params, etc.), b/c I do not know them 'by heart'.
Thing is, my experience w/'programming' is AutoLISP, which I used 'back in the day' to write small 'programs' for AutoCAD 'routines'.
Any help would be much appreciated.
Thanx!
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
