Export DXF
Export DXF
ryangilesZELTN
Export DXF
ryangilesZELTN
I have the follow iLogic rule to prompt for a DXF export when saving. It ran fine untill I updated to 2022, now I am getting the following error. I'm not familiar with iLogic code, anyone have any ideas?
'query user
question = MessageBox.Show(".DXF Export Required?", "DXF Export",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
          'set condition based on answer
            If question = vbYes Then
' Get the DXF translator Add-In.
path_and_nameDXF = ThisDoc.PathAndFileName(False)
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\Users\Farr\Documents\Inventor\DXF_EXPORT_INI\DXF_EXPORT.ini"
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
oDataMedium.FileName = path_and_nameDXF & ".dxf"
Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End If
Ralf_Krieg
Hello
Is this path already correct?
R. Krieg
RKW Solutions
www.rkw-solutions.com
ryangilesZELTN
I changed that path to what's in the following code. It runs now, however it is exporting it into a .ZIP file under the part number, rather than into the directory as all the other files. Any ideas as to why that maybe happening?
'query user
strIniFile = "C:\Users\Public\Documents\Autodesk\Inventor 2022\Design Data\DWG-DXF\exportdxf.ini"
End If
End If
Ralf_Krieg
Hello
Check exportdxf.ini for the option set USE TRANSMITTAL=No
R. Krieg
RKW Solutions
