Export a flat surface to DXF without using command manager
MJBusseyMS
Message 1 of 8
MJBusseyMS
Is there a way through the Inventor API to export a specified surface in a part or assembly context without using the command manager?
Replies (7)
Message 2 of 8
bradeneuropeArthur
Maybe this will help..
Public Sub WriteSheetMetalDXF()
    ' Get the active document.  This assumes it is a part document.
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the DataIO object.
    Dim oDataIO As DataIO
    Set oDataIO = oDoc.ComponentDefinition.DataIO
    ' Build the string that defines the format of the DXF file.
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Outer"
    ' Create the DXF file.
    oDataIO.WriteDataToFile sOut, "C:\temp\flat2.dxf"
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
WCrihfield
Hi @MJBusseyMS .
@DRoam actually already created a post in Inventor Ideas for this issue, which stemmed from their earlier post here on this forum.
Ideas Post is here.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 8
bradeneuropeArthur
Or this:
Public Sub PublishDXF()
    ' Get the DXF translator Add-In.
    Dim DXFAddIn As TranslatorAddIn
    Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        Dim strIniFile As String
        strIniFile = "C:\tempDXFOut.ini"
        ' Create the name-value that specifies the ini file to use.
        oOptions.Value("Export_Acad_IniFile") = strIniFile
    'Set the destination file name
    oDataMedium.FileName = "c:\tempdxfout.dxf"
    'Publish document.
    Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
WCrihfield
@bradeneuropeArthur, where does the information and formatting for that line of code come from.
I've seen similar lines several times before, but am unfamiliar with its logic and specific purpose/use.
Is there a way of extracting that information from the similar manual process, or from another coded process?
Is it from another code language like XML, HTML, C# or similar?
Wesley Crihfield
Message 6 of 8
Curtis_Waguespack
Hi @MJBusseyMS
Here's an example ilogic rule, it might need some error checking to ensure that the face is a planer face so that the sketch can be made,  (never mind that, I forgot the pick filter was filtering for planer surfaces only ) or other things, but this should get you pointed in the right direction.
Out of curiosity, why does using the command manager not work for your needs?
I hope this helps.
Curtis
Dim oCompDef As PartComponentDefinition
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPrompt1 As String
oPrompt1 = "Select a face to export..."
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick _
	(SelectionFilterEnum.kAllPlanarEntities, oPrompt1)
If oFace Is Nothing Then
	Return 'exit rule
' Create a new sketch.
'True specifies To include the edges of the face in the sketch.
Dim oSketch As PlanarSketch
oSketch = oCompDef.Sketches.Add(oFace, True)
oDataIO = oSketch.DataIO
''Check for the DXF folder and create it if it does not exist
oFolder = "C:\temp\DXF\"
If Not System.IO.Directory.Exists(oFolder) Then
	System.IO.Directory.CreateDirectory(oFolder)
oDataIO.WriteDataToFile ("DXF",oFolder & "My_DXF.dxf")
oSketch.Delete
Process.Start(oFolder)
Message 7 of 8
MJBusseyMS
Forge Design Automation uses Inventor Server for doing Inventor automation "at scale".  Inventor Server does not have any of the Inventor UI, and does not support command manager (it's not part of the Inventor Server API at all).  Therefore I need a way to export a surface without using it.
Message 8 of 8
lmc.engineering
I don't know much about Forge, but can you make use  of named Geomerty? Something like this mixed in with Curtis's code sample:
Sub main()
	Dim oDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
	Dim oFace As Face
	oFace = ReturnFaceFromNamedGeo(oDoc, "Face0")
		Return 'exit rule
	oSketch = oDef.Sketches.Add(oFace, True)
	oSketch.Delete
End Sub
Function ReturnFaceFromNamedGeo(oPart As PartDocument,EntityName As String, Optional SolidBodyNo As Integer = 1) As Face
    Dim oDef As PartComponentDefinition = oPart.ComponentDefinition
    Dim oFaces As Faces = oDef.SurfaceBodies(SolidBodyNo).Faces
    Dim AttSet As AttributeSet
    Dim AttSets As AttributeSets
    For Each oFace In oFaces
        AttSets = oFace.AttributeSets
        If AttSets.NameIsUsed("iLogicEntityNameSet") Then
            AttSet = AttSets.Item("iLogicEntityNameSet")
            For Each Att In AttSet
                If Att.Value() = EntityName Then
		      Return oFace
            Next
    Next
    Return Nothing
End Function
