Exclude from print if Model iProperty exists
dliteful
dliteful
Love the iLogic Batch print to PDF from assembly, but I've been asked to exclude certain file types that contain the Model iProperty Value of "SPA" under the Summary Tab in Category field.
Any help would be greatly appreciated.
Attached is the code I'm using.
put somthing like this in your code when you open a idw. I use this for something similar
For Each oOcc In oLeafOccs 'this is your code
	 oDoc = oOcc.Definition.Document ' not new
Dim emodel As String = oDoc.DisplayName 'use this
ex = Right(emodel,4) 'with this are you sure you have a ex
If ex <> ".ipt"
emodel = emodel & ".ipt"
End If
eTest= Left(iProperties.Value(emodel,"summary","category"),6) 'here you can make a if statement
If eTest <> "Laser" Then
chandra.shekar.g
Autodesk Support
Autodesk Support
@dliteful ,
Hoping that below iLogic code helps to exclude components which contains "SPA" Summary Category.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
End If
For Each oRefDoc In oAsmDoc.AllReferencedDocuments
	Dim oCategory As String
	oCategory = oRefDoc.PropertySets.Item("Inventor Summary Information").Item("Category").Value
	If oCategory <> "SPA" Then
		Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
	End If
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
