Exclude components using iLogic?
Message 1 of 9
Is it possible to Exclude components using iLogic? I know how to disable or suppress, but I would like to exclude them instead - as this will also suppress all related constraints.
Replies (8)
Message 2 of 9
clutsa
It's as easy as you hope it would be
Rod50 = Component.InventorComponent("ROD_50")
Rod50.Excluded = True
or if you really want to save lines of code
Component.InventorComponent("<Your part name>").Excluded = True
 and of course =false to "unexclude"
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 9
clutsa
Here is also some bonus code so that the parts can be removed on the drawing.
Dim doc As AssemblyDocument
doc = ThisDoc.Document
compDef = doc.ComponentDefinition
For Each part In compDef.Occurrences
        If part.Excluded Then
		part.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
	Else
		part.BOMStructure = BOMStructureEnum.kDefaultBOMStructure
Next
Then in the "Drawing View" wizard under the "Model State" tab in the "Reference Data" section change "Line Style" to "Off"
Message 4 of 9
Great, thanks!
Message 5 of 9
meck
This works fine.
Is there a way to specify a sub-assembly's occurrence name and exclude a component in only that sub-assembly. Your code will exclude the component in all sub-assemblies that have it.
Just trying to raise the bar. 😁
Any suggestions would be greatly appreciated!
Mike
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Message 6 of 9
clutsa
Couple of things on this subject. Before Inv2021 you could .Exclude a component in a regular assembly (non-iAssembly Factory) but you evidently were not supposed to because .Exclude was only supposed to be for iAssembly factories. That said you can still use .Exclude in Inv2021 but only on iAssembly Factories (they "fixed the glitch" so Milton is no longer receiving a paycheck in 2021.😭)
@meck For your question I believe the only way you could achieve what you're asking (in Inv2018) is to have the parts be different members of the same iAssembly Factory. Give them unique member names but the same part number and then switch between members.
Message 7 of 9
Mario.van.der.raaf
I am trying to include and exclude parts based on your syntax above:
Component.InventorComponent("ASME B16.5 Flange Welding Neck - Class 150 20:1").Excluded = True
But get the following error
This is in an assembly where I am moving from using iAssembly's to only using iLogic. The reason for this is because some changes in my parametric model require iAssemblys to be regenerated. This regenerating takes place for all iAssembly configurations and therefore takes a lot of time.
Do I understand correctly that Component.InventorComponent.exlude is no longer available from Inventor 2021 and on?
Message 8 of 9
clutsa
Sorry for the late response. I'm a bit rusty on the topic but that sounds right. You can now only use the .exclude on iAssemblies. If you are using 2022 you can look into Model States that may be able to do what you want. I haven't had to use them yet but this post seems like a good start.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/create-model-states-using-ilogic/m-p...
When I was forced to move away from .exclude I moved to ThisAssembly.BeginManage() and it's amazing! Completely changed the game. The answer in this post uses a drawing as an example, not an assembly, but it's the same concept. Wish I could find a better post about BeginManage
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-beginmanage-and-endmanage-why...
Message 9 of 9
Mario.van.der.raaf
Thanks for the reply, I have changed my model to use suppressions and model states. This has led me to another problem which I describe in this post: Re: Suppressing part within a nested assembly using iLogic - Autodesk Community - Inventor
