Drawing - Ilogic
Drawing - Ilogic
Boopathi_Sivakumar
Drawing - Ilogic
Boopathi_Sivakumar
Hi fellas,
           I want to Save my Drawing as Pdf through Ilogic For the File Names will be Typed by the user. I don't Have much skills in VB So couldn't get the idea,
I ll Show you what I did
NewName = InputBox("Name to Save", "Save As", "")
ThisDoc.Document.SaveAs(ThisDoc.ChangeExtension(".pdf"), True)
 NewName is the User parameter in the drawing, So whatever I type the parameter will hold the value,
How Can i use the value as my File Name ? that's the question.
Hope You Guys get it.
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
mcgyvr
See if this example helps you..
http://inventortrenches.blogspot.com/2011/07/ilogic-to-save-pdf-files-to-new.html
Curtis_Waguespack
@Boopathi_Sivakumar wrote:
...I want to Save my Drawing as Pdf through Ilogic For the File Names will be Typed by the user...
Hi @Boopathi_Sivakumar,
Using the example that mcgyvr linked to, I've combined another example found at this link, so that the user is presented a dialog box in which to type the file name.
This negates the need for the user parameter for gathering the file name, but if you must use the parameter for other reasons, this example could be modified to use it also.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'define the active document
oDoc = ThisDoc.Document
'create a file dialog box
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'filter file type
oFileDlg.Filter = "PDF files (*.pdf)|*.pdf"
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = iProperties.Value("Project", "Part Number")
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
On Error Resume Next
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the imput
If Err.Number <> 0 Then
MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
MyFile = oFileDlg.FileName
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'set PDF options
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
 'Set the PDF target file name
oDataMedium.FileName = MyFile
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Boopathi_Sivakumar
Thanks for Both of you guys,
          I have made some changes to your code and it works perfectly. I have one more doubt is it  possible to export the drawing to autocad 2000 version through i-logic?
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
