Excel linked with BOM
Is there a way to link a custom Excel sheet to an assembly BOM?
So that when a part in the assembly is changed, the Excel sheet that contains that part with-in the list is automatically updated
Jef_E
This would be tricky.. What if you change the part and the assembly document is not open?
Also, it would be expensive in resources usage. So I would not recommend it.
Best to do a synchronization at the end to update the excel.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
