Workplane Switching on Sketch Creation-Switch Back with Ilogic?
I would like to keep the work plane from switching on sketch creation , but when I select no new sketch it still flips the planes around in a direction that I dont want to use , I want it preset so that other users dont have to switch it back around every time do i would like to set it in the template if possible , i was hoping that there was some Ilogic that would flip it back to the correct plane that I desire , attached is a video of what I am trying to describe.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Kesseltine,
Better to create a template than writing iLogic. Please find the following steps to create template.
  • Create a new part from existing template.
  • Set desire workplane orientation as shown below
  • Set Current view as Home view as shown below.
  • Save the part file as template by navigating
     file -> Save As -> Save Copy As Template. Give a template name as you wish.
Next time, when are creating a new part. Use the same template.
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
