Event Trigger on Vault Check-In
We're interested in rolling out some automation to our company that checks certain iProperties before allowing a user to check in a model. Is there any way to trigger a rule "Before Check-In" or to write custom triggers?
Tighe
bradeneuropeArthur
What version of vault are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Vault Professional 2019
bradeneuropeArthur
Based on using an add in for inventor you could use the prevaultcheckinevents!
Don't know if this is what you want.
For ilogic I don't know if this is possible easily!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
marcin_otręba
it can be done in addin  troug OnActivateCommand event:
for example:
 Private Sub ui_OnActivateCommand(CommandName As String, Context As NameValueMap) Handles oUserInputEvents.OnActivateCommand
            On Error Resume Next
            Select Case CommandName
                Case "VaultCheckin"
'or
                Case "VaultCheckinTop"
            End Select
        End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
bradeneuropeArthur
this is not before, and will not trigger before
This is only if the command is activated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
marcin_otręba
I was using this approach before i switched to vault api DocumentService.AddFileEvents.Pre and DocumentService.CheckinFileEvents.Pre events. and to be honest i still use it because when you will use documentservice your code will be fired after you click ok in vault check in window in inventor.
when using on activate command the code will be fired before vault check in window will be displayed, for me this one is better because i will finnish all before gatering check in files.
