Error when creating an adaptive work plane for an occurrence in assembly
ngocson8335
ngocson8335
Hello Everyone,
I am trying to create an adaptive work plane for an occurrence from a selected face of a different occurrence in the assembly context.
        g_inventorApplication = Marshal.GetActiveObject("Inventor.Application")
        _assemblyDoc = g_inventorApplication.ActiveDocument
        Dim _assemblyDef As Inventor.AssemblyComponentDefinition
        _assemblyDef = _assemblyDoc.ComponentDefinition
        Dim _toFace As Object
        _toFace = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a end face")
        Dim _occs As Inventor.ComponentOccurrences
        _occs = _assemblyDef.Occurrences
        Dim _occ As Inventor.ComponentOccurrence
        _occ = _occs.Item(1)
        Dim _partDef As Inventor.PartComponentDefinition
        _partDef = _occ.Definition
        Dim _defineLengthPlane As Inventor.WorkPlane
        _defineLengthPlane = _partDef.WorkPlanes.AddByPlaneAndOffset(_toFace, 0, False)
        _defineLengthPlane.Adaptive = True
        _occ.Adaptive = True
Error
Please help me in this case.
Many thanks.
Ngoc Son
Autodesk User
bradeneuropeArthur
Addaptivity within an assembly for the same part, with two different references is not possible!
Is this what you are doing?
Than it is not possible.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
