Error Message when Closing Inventor 2017
Martin-Winkler-Consulting
Advisor Advisor
i wrote some Tools as AddIn in VB.Net.
With Inventor 2016 they work fine.
In Inventor 2017 i get an error message that a COM object is disconnected from the RCW and could not be used any longer (see attachment).
This Error is initialized in the Closing section of the AddIn after closing InventorApp.
 ''' <summary>
    ''' Do cleanups in it such as releasing COM objects or forcing the GC to Collect when necessary.
    ''' </summary>
    Public Sub Deactivate() Implements ApplicationAddInServer.Deactivate
        ' Add more cleanup work below if necessary, e.g. remove even handlers, flush and close log files, etc.
        ' Release COM objects
        ' Add more FinalReleaseComObject() calls for COM objects you know, e.g.
        'if (comObj != null) Marshal.FinalReleaseComObject(comObj);
        ' Release the COM objects maintained by InventorNetAddinWizard.
        For Each button As InventorButton In AddinGlobal.ButtonList
            If button.ButtonDef IsNot Nothing Then
                Marshal.FinalReleaseComObject(button.ButtonDef)
        Next
        'Menüleisten schliessen
        If AddinGlobal.RibbonPanelPart IsNot Nothing Then
            Marshal.FinalReleaseComObject(AddinGlobal.RibbonPanelPart)
        If AddinGlobal.RibbonPanelAssembly IsNot Nothing Then
            Marshal.FinalReleaseComObject(AddinGlobal.RibbonPanelAssembly)
        If AddinGlobal.RibbonPanelDrawing IsNot Nothing Then
            Marshal.FinalReleaseComObject(AddinGlobal.RibbonPanelDrawing)
        If AddinGlobal.RibbonPanel3DCSBrowser IsNot Nothing Then
            Marshal.FinalReleaseComObject(AddinGlobal.RibbonPanel3DCSBrowser)
        'Closing Inventor
        If AddinGlobal.InventorApp IsNot Nothing Then
            Marshal.FinalReleaseComObject(AddinGlobal.InventorApp)
      End Sub
Any idea how i can recognize which COM Object creates the error message?
When i have a look at the debugger there is no COM Object openend at this time.
Best Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
flora_fang
From the error dialog, it seems related with Guided Tutorial addin, Would you please unload the Guided Tutorial nd see the problem still reproduce?
Flora Fang
Flora.Fang@autodesk.com
Software Quality Assurance
Design & Manufacturing
Autodesk, Inc.
Hi flora,
thanks for your reply. You are right. I tested it without the interactive tutorial and the error was gone away.
But what can i do? I do not want to deactivate interactive tutorial !?
Martin Winkler
CAD Developer
GeorgK
Hello @flora_fang,
I get the same error. Is this error confirmed and got a ticket number?
Georg
Hi GeorgK,
look here for a temporarily solution:
@Anonymous admin
Perhaps it is useful to make one Thread from both
Martin Winkler
CAD Developer
