COM Object that has been separated from its underlying RCW cannot be used
NachoShaw
Advisor Advisor
NachoShaw
Hi
Anyone know what this error is? Never had it last week but it appears now since I ran an update.... Ive tried turning just about everything off but I still get it when I close inventor. It is related to my addin I am working on because when I unload it, I don't get the error.
Here is the error
Here are my references
Any help greatly appreciated, I really don't want to have to start from scratch 🙂
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Martin-Winkler-Consulting
may be the same problem as in my post :
https://forums.autodesk.com/t5/inventor-customization/error-message-when-closing-inventor-2017/m-p/7...
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
NachoShaw
Hi Martin
Weird. I too unloaded the interactive Tutorial and now i do not get the error. That is strange because i dont have anything in my application that would require the interactive tutorial. Would like to establish exactly what the error is because i cant make an addin that requires this to be switched off, especially when other addins don't experience the same issue...
@Anonymous
Have you ever seen this before?
Regards
Nacho
Nacho
Hi Nacho,
it seems to be that this error was new up to inventor 2017. In 2016 it doesn't happened.
I solved it temporarily by deleting this lines in the addin server class:
 'If AddinGlobal.InventorApp IsNot Nothing Then
   'Marshal.FinalReleaseComObject(AddinGlobal.InventorApp)
 'End If
Now, Autodesk should have a look at the interactive tutorial dll.
Martin Winkler
CAD Developer
