Error Code 104
Error Code 104
Error Code 104
I get a error code 104. What is this?
What is the solution?
NSBowser
Please be aware that this question is not an Inventor Customization issue, which is where this post was made. Always post your questions in the most appropriate forum in order to get the best results.
A quick search for your issue turned up the following link.
https://forums.autodesk.com/t5/inventor-general-discussion/adlm-error-104-error-initializing-the-usa...
Consider posting this question in one of the forums in these related links, you'll have a better chance of getting a response.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
