Use Excel worksheet functions MATCH and INDEX in Ilogic
CAD_CAM_MAN
CAD_CAM_MAN
Inventor 2015...
I am writing an Ilogic program that accesses data from an Excel workbook.
I would like to use the "MATCH" and "INDEX" worksheet functions in the Ilogic code however I am not sure if they are supported. I have used similar code with ".WorksheetFunction" in VB.net but can't seem to get it to work in Ilogic. I get the following message...
"Unable to get the Match property of the WorksheetFunction class"
 Code as follows...
TEST = GoExcel.Application.WorksheetFunction.Match(THREAD_DIAMETER,GoExcel.CellValues("A1","A1000"),0)
To start I want to find the cell that holds the current value of the THREAD_DIAMETER parameter. This only uses the Match function as the portion where I need the Index function is built on the return of the match.
Is it possible to use the Match and Index functions in Ilogic? If yes what am I missing? Can you provide a sample syntax?
HermJan.Otterman
you can use the first defaut snippet from the excel data links in iLogic:
i = GoExcel.FindRow("filename.xls", "Sheet1", "columnName", "<=", 0.2, "columnName", "<=", 4.1)
index = GoExcel.FindRow("YourExcelfilename.xls", "Sheet1", "A", "=", THREAD_DIAMETER)
it will look for the Value of "Thread_Diameter" in Column "A" on "Sheet1" in YourExcelFile
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Owner2229
Hi, here is how to use the ExcelApp instead of GoExcel. It's similiar to VB.Net.
You might want to try these functions with this.
excelApp = CreateObject("Excel.Application")
excelApp.Visible = False
excelApp.DisplayAlerts = false
excelWorkbook = excelApp.Workbooks.Open(Filename: = "C:\Path\MyExcelTable.xlsx")
excelWorkbook.Save
excelWorkbook.Close
excelApp.Quit
excelApp = Nothing
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
