How to create flatpattern using C#?
I'm developing an application to check if there is flat pattern, if not, the application must create.
To check if the flatpattern exists, I use the following code.
                    SheetMetalComponentDefinition sheetMetalCompDef = (Inventor.SheetMetalComponentDefinition)prtDoc.ComponentDefinition;
                    if (!sheetMetalCompDef.HasFlatPattern) {
                        //code to create the flatpattern
Anyone know how I could do to create the flatpattern?
Thanks!
xiaodong_liang
Autodesk Support
Autodesk Support
SheetMetalComponentDefinition.Unfold or Unfold2 is the way to create flat pattern.
