Error after running leader annotation rule
emilda.chiuye
emilda.chiuye
Hello.
I am trying to run this leader annotated text for a drawing however, I come across this error.
Please assist in figuring out what "Public member 'Sheet'on type'_DocumentClass'not found " means.
Here is the code,
Sub Main AddLeaderNote()
     Dim oDrawDoc As DrawingDocument = ThisDoc.Document 'then no need to reference the drawing document. Either or)
'Reference this drawing sheet
	Dim DrawSheet As Sheet = oDrawDoc.Sheet("STANDARD SUPERHEATER DWG")
'Reference this drawing view
	  Dim oView As DrawingView
	  oView = ActiveSheet.View("FRONT ELEVATION").View
    Dim oDrawingCurveSegment As DrawingCurveSegment
     oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
    Dim oDrawingCurve As DrawingCurve
     oDrawingCurve = oDrawingCurveSegment.Parent
    Dim oMidPoint As Point2d
     oMidPoint = oDrawingCurve.MidPoint
    Dim oTG As TransientGeometry
     oTG = ThisApplication.TransientGeometry
    Dim oLeaderPoints As ObjectCollection
     oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
'Create a few leader points.
     oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
     oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
'Create an intent and add to the leader points collection.
'This is the geometry that the leader text will attach to.
     Dim oGeometryIntent = DrawSheet.CreateGeometryIntent("User Parameters,FCW1_AT_TUBEC")
'Select dimension text position
     Dim textOrigin = DrawSheet
     oLeaderPoints.Add(oGeometryIntent)
    Dim sText As String
    sText = "API Leader Note"
    Dim oLeaderNote As LeaderNote
     'oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add("A1 Landscape:1" )
     ActiveSheet = ThisDrawing.Sheet("A1 Landscape:1")
    Dim oFirstNode As LeaderNode
     oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
    Dim oSecondNode As LeaderNode
     oSecondNode = oFirstNode.ChildNodes.Item(1)
    Call oFirstNode.InsertNode(oSecondNode, oTG.CreatePoint2d(oMidPoint.X + 5, oMidPoint.Y + 5))
End Sub
A.Acheson
Th error is here.
You are attempting to look for a single sheet by its name in the active document without first looking in the collection of sheets.
A tip if you have declared the sheet type in  oDrawDoc.(and then type sheet) nothing will come up as a tool tip as the sheet is not the collection. Where as when you have the correct collection the tooltip will appear explaining it's functionality.
You can get DrawSheet by a few methods
Dim DrawSheet As Sheet = oDrawDoc.Sheets.Item("STANDARD SUPERHEATER DWG")
Or
Dim DrawSheet As Sheet = oDrawDoc.Sheets("STANDARD SUPERHEATER DWG")
Or
The correct ilogic method should be like this
DrawSheet = ThisDrawing.Sheet(“sheetname”)
Regards
Alan
emilda.chiuye
Thank you so much for this educative assistance!
I now run the code and it says the parameter is incorrect.
This is the parameter I am trying to refer to
Which line in the code is incorrectly referenced or worded? I am able to refer to these pre-defined parameters manually though.
     oLeaderPoints.Add(oTG.CreatePoint2d("User Parameters,FCW1_AT_TUBEC"))
     oLeaderPoints.Add(oTG.CreatePoint2d("User Parameters,FCW2_AT_TUBEC"))
     Dim oGeometryIntent As GeometryIntent
    Dim sText As String
    Call oFirstNode.InsertNode(oSecondNode, oTG.CreatePoint2d("User Parameters,FCW1_AT_TUBEC"))
End Sub
emilda.chiuye
If there is no solution to the 2D annotation then I would greatly appreciate assistance on the 3D annotation instead.
With the help of @Ralf_Krieg  this shorter 3D annotation rule works however my issue is with line 9, you see previously there was a command Manager that prompted me to "select a face" and all I wish is for the leader to be set to a feature in the model tree so that when I run the code the annotation will pop up pointing to Revolved Feature1 for example and so on. So should I suppress this features then so too does the 3D leader annotation.
Regards
Dim oDoc As Inventor.PartDocument = ThisDoc.Document
Dim oDef As Inventor.PartComponentDefinition = oDoc.ComponentDefinition
Dim oTG As Inventor.TransientGeometry = ThisApplication.TransientGeometry
Dim oRepMan As Inventor.RepresentationsManager = oDef.RepresentationsManager
Dim oDesignViewReps As Inventor.DesignViewRepresentations = oRepMan.DesignViewRepresentations
Dim oFace As Inventor.Face = FeaDture.IsActive("Revolved Feature1")
Dim oAnnoPlaneDef As Inventor.AnnotationPlaneDefinition = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oDef.WorkPlanes(2))
Dim oLeaderPoints As Inventor.ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
oLeaderPoints.Add(oTG.CreatePoint(1, 0,1))
Dim oLeaderIntent As Inventor.GeometryIntent = oDef.CreateGeometryIntent("FCW1 AT TUBE C ")
oLeaderPoints.Add(oLeaderIntent)
Dim oLeaderDef As Inventor.ModelLeaderNoteDefinition = oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, "2000", oAnnoPlaneDef)
Dim oLeader As Inventor.ModelLeaderNote = oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
A.Acheson
What is the end goal with placing this annotation? Do you want to place it on a specific part or to inject the user parameter into the text of the leader?
A few pictures of the manually created leader and what they are attaching too. If this is an assembly drawing you will likely need to attach the leader to a named face in a part as assembly named faces are not supported as of yet.
This post here is working with assembly drawing leaders
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/leader-text-on-an-assembly-edge/td-p/63...
Regards
Alan
emilda.chiuye
I would like to achieve differentiating between new and and existing items on the tube, and yes they (3D leader annotations) should be attached to a parameter which I have set already. There are a number of these revolved features however they need to be called out with different names/numbers as they vary from new to existing.
I have attached a snippet of it accomplished manually. So when one or more of these features are hidden so will the annotation that goes along with it. In the meantime let me peruse this link you sent, see if I can make sense of it....
Parameters to which the annotations should be set.  Not sure of my statement but is it not easier to set this up in the model environment then all I do is retrieve these dimensions in idw as others on this forum have previously done.
Ralf_Krieg
Hello
Hopefully I understand what happens when.
You have a part wih one or more revolve feature(s). The features unique named to identify them. You have one or more user parameter in your part. There is an relation between the revolve feature name and the parameter namer. I assume the feature and the corresponding parameter have same name.
There seem's to be an error in current Inventor release (2022.1) . If the model annotation with a linked user parameter is deleted, the user parameter is also deleted.
Private Sub Main()
    Dim oApp As Inventor.Application= ThisApplication
    Dim oDoc As Inventor.PartDocument= oApp.ActiveDocument
    Dim oDef As Inventor.PartComponentDefinition= oDoc.ComponentDefinition
    Dim oTG As Inventor.TransientGeometry= oApp.TransientGeometry
    Dim oRepMan As Inventor.RepresentationsManager= oDef.RepresentationsManager
    Dim oDesignViewReps As Inventor.DesignViewRepresentations= oRepMan.DesignViewRepresentations
    Dim oOuterFace As Inventor.Face
    Dim oRevolveFeature As Inventor.RevolveFeature
    For Each oRevolveFeature In oDef.Features.RevolveFeatures
        If Feature.IsActive(oRevolveFeature.Name) And oRevolveFeature.HealthStatus = HealthStatusEnum.kUpToDateHealth Then
            If CheckExistLeader(oRevolveFeature) = False Then
                oOuterFace = GetOuterFace(oRevolveFeature)
                Dim oAnnoPlaneDef As Inventor.AnnotationPlaneDefinition= oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oDef.WorkPlanes(2))
                Dim oLeaderPoints As Inventor.ObjectCollection= oApp.TransientObjects.CreateObjectCollection
                Dim oIntentPoint As Point
                Select Case oOuterFace.SurfaceType
                Case SurfaceTypeEnum.kConeSurface:
                    oIntentPoint = GetPointOnCone(oOuterFace)
                Case SurfaceTypeEnum.kCylinderSurface:
                    oIntentPoint = GetPointOnCylinder(oOuterFace)
                End Select
                Dim oLeaderIntent As Inventor.GeometryIntent= oDef.CreateGeometryIntent(oOuterFace, oIntentPoint)
                'The Leaderpoint should be relative positioned to the LeaderPoint 1
                Call oLeaderPoints.Add(oTG.CreatePoint(oIntentPoint.X + 1, 0, oIntentPoint.Z + 1))
                Call oLeaderPoints.Add(oLeaderIntent)
				Dim sFormattedText As String
                sFormattedText = "NaN"
                Dim oLeaderDef As Inventor.ModelLeaderNoteDefinition = oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, sFormattedText, oAnnoPlaneDef)
                Dim oLeader As Inventor.ModelLeaderNote= oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
				oLeader.Definition.Text.FormattedText = GetParamValue(oRevolveFeature)
                oOuterFace = Nothing
    Next
End Sub
Private Function CheckExistLeader(ByVal oRevolveFeature As RevolveFeature) As Boolean
    Dim oPartCompDef As PartComponentDefinition = oRevolveFeature.Parent
    Dim oLeaderNotes As ModelLeaderNotes = oPartCompDef.ModelAnnotations.ModelLeaderNotes
	Dim oFace As Face
    Dim oIntentFace As Face
    Dim oLeaderNote As ModelLeaderNote
	For Each oLeaderNote In oLeaderNotes
		oIntentFace = oLeaderNote.Definition.Intent.Geometry
		For Each oFace In oRevolveFeature.Faces
			If oIntentFace Is oFace Then
				Return True
		Next
    Next
End Function
Private Function GetOuterFace(ByVal oRevolveFeature As Inventor.RevolveFeature) As Inventor.Face
        If oFace.SurfaceType = SurfaceTypeEnum.kConeSurface Or oFace.SurfaceType = SurfaceTypeEnum.kCylinderSurface Then
            If Not oOuterFace Is Nothing Then
                If oFace.Geometry.Radius > oOuterFace.Geometry.Radius Then
                    oOuterFace = oFace
            Else
                oOuterFace = oFace
    Next
	GetOuterFace = oOuterFace
End Function
Private Function GetPointOnCone(ByVal oFace As Face) As Point
    Dim oCone As Cone= oFace.Geometry
    Dim oSB As SurfaceBody= oFace.SurfaceBody
    Dim oBasis As Point = oCone.BasePoint
    Dim oRadius As Double = oCone.Radius
    Dim oEnts As Inventor.ObjectsEnumerator
    Dim oPoints As Inventor.ObjectsEnumerator
    Dim oVector As Vector= ThisApplication.TransientGeometry.CreateVector(0, 1, 0)
    Call oSB.FindUsingRay(oBasis, oVector.AsUnitVector, oRadius, oEnts, oPoints, False)
    If oEnts.Count > 0 Then
        Dim i As Integer
        For i = 1 To oEnts.Count
            If oEnts(i) Is oFace Then
                GetPointOnCone = oPoints(i)
        Next
End Function
Private Function GetPointOnCylinder(ByVal oFace As Face) As Point
    Dim oCylinder As Cylinder= oFace.Geometry
    Dim oBasis As Point = oCylinder.BasePoint
    Dim oRadius As Double= oCylinder.Radius
    Dim oVector As Vector = ThisApplication.TransientGeometry.CreateVector(0, 1, 0)
        Dim i As Integer
            Call ThisApplication.ActiveDocument.SelectSet.Select(oEnts(i))
            Select Case oEnts(i).Type
            Case kVertexObject:
            Case kEdgeObject:
                Dim oEdge As Edge= oEnts(i)
                Dim oConFace As Face
                For Each oConFace In oEdge.Faces
                    If oConFace Is oFace Then
                        GetPointOnCylinder = oPoints(i)
                Next
            Case kFaceObject:
            End Select
        Next
End Function
Private Function GetParamValue(ByVal oRevolveFeature As RevolveFeature) As String
    GetParamValue = "NaN"
    Dim oPartDoc As PartDocument= oRevolveFeature.Parent.Document
    Dim oUserParam As UserParameter
    For Each oUserParam In oPartDoc.ComponentDefinition.Parameters.UserParameters
        If oRevolveFeature.Name = oUserParam.Name Then
            GetParamValue = "<Parameter Resolved='True' ComponentIdentifier='" & oPartDoc.FullFileName & "' Name='" & oUserParam.Name & "' Precision='" & oUserParam.Precision & "'>" & oUserParam.Value & "</Parameter>"
            Exit For
    Next
End Function
R. Krieg
RKW Solutions
www.rkw-solutions.com
