equation curve by iLogic
binsar_z
binsar_z
Hi All,
How to create an iLogic to drive 3D equation curve?,
in sample below, 136 = pitch, 345 = radius of helical curve. So I need the easier way if I want to change input by other parameter for example change x(t) = 136+13.625*t^2 to make an accelerated pitch.
Thanks for any help
adam.nagy
Autodesk Support
Autodesk Support
I already logged the issue in our system and prepared my answer when I got back to my code to have a final look and realized what the problem was with calling SetEquation curve.
It works now 🙂
http://adndevblog.typepad.com/manufacturing/2014/07/change-equation-curve-values.html
Cheers,
Adam Nagy
Autodesk Platform Services
binsar_z
Hi, Adam,
Many thanks for helped
Regads
Binsar
binsar_z
Hi Adam, Please help again, I'm using Inventor 2013, I got this error.
adam.nagy
Autodesk Support
Autodesk Support
Hi Binsar,
That's because the API support for it was added in Inventor 2014:
http://images.autodesk.com/adsk/files/Inventor_2014_API.zip
Sorry for the bad news 😞
Cheers,
Adam Nagy
binsar_z
You are correct Adam, had tested previously in Inventor 2014 (trial), but our company decided to keep using Inventor 2013 till jump to Inventor 2015 begin next year. Will it working in 2015 version?
Binsar.
