Enter value manually or calculate with formula with Ilogic
mat_hijs
mat_hijs
This is a hard one for me to explain. So I have a parameter, which in some cases I want to enter manually, and in other cases I want to be calculated by a formula. It's based on the values of about 6 parameters. How could I solve this easily using Ilogic? Ideally I would like to be able to enter everything in a form, so basically I want it greyed out if it's calculated, and not when I have to enter it manually.
I can imagine this is not possible on a form, if so, how else could I solve this problem?
johnsonshiue
Hi Mathijs,
I am not an iLogic expert but I can tell you that this is the exact problem iLogic can solve. Basically, you need to set up the condition when the value needs to be entered and when the value needs to be calculated. Please share your attempt so far. We have many iLogic experts on the forum to help take a look.
Many thanks!
Software Test Engineer
