Enable "Copy Model iProperties"
mrawesomelemons
Message 1 of 26
mrawesomelemons
I have made a script to update all the iProperties before saving.
This only works for custom iProperties if the option "Copy model iproperties" is enabled and the custom iproperties I want to copy are selected.
In my template I have enabled this option but for my older drawings I have this option disabled. There are so many drawings I can't possibly go through them manually and change the option so I want to make an iLogic rule or something alike to enable this option and select the custom iproperties I want to have copied and updated.
Is there any way to enable and select custom iProperties to copy in de document settings?
Replies (25)
Message 2 of 26
mrawesomelemons
Anyone?
Message 3 of 26
bradeneuropeArthur
Write your code by yourselves and define there what proprieties need to be copied.
Do you have a list of properties that need to be synchronized?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 26
mrawesomelemons
Thank you for your reply!
I know how to automatically update/copy the properties but not how to enable the custom properties to be enabled.
I want to enable this checkbox automatically:
Message 5 of 26
bradeneuropeArthur
As far as I know this is not possible.
I was also searching this for a while, but with no success.
If i am remembering correct this was also confirmed that this is not included in the API..
I wrote my own code for this!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 26
mrawesomelemons
Thank you for your help.
What do you mean with:
You wrote your own code to do this? If so, could you link it?
Message 7 of 26
bradeneuropeArthur
I read all properties that I need by my code and put it into the file needed for.
I do this with an add-in under conditions...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 26
mrawesomelemons
I'm afraid I don't really follow. Could you guide me on how to do that?
Message 9 of 26
bradeneuropeArthur
Yes of course.
can you provide me a list of properties you want to synch between the model and the drawing?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 26
mrawesomelemons
Thank you very much.
The custom properties have the following names:
AIMD_ITEM_MODEL_TYPE
PART NUMBER
TITLE
Message 11 of 26
bradeneuropeArthur
are you familiar with add ins in Vb.net or VBA
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 26
mrawesomelemons
I haven't used those before.
Message 13 of 26
bradeneuropeArthur
how do you prefer the code:
  1. VBA
  2. VB.net add in
  3. Vb.net standalone app
  4. I logic
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 26
mrawesomelemons
I would prefer iLogic since I have used that before and already implemented an iLogic rule so it would be easier to just add another.
Message 15 of 26
bradeneuropeArthur
here you are:
Public Sub Main()
Dim a As Application
a = ThisApplication
Call UpdateCopiedModelPropertiesConventional(a, "AIMD_ITEM_MODEL_TYPE")
Call UpdateCopiedModelPropertiesConventional(a, "PART NUMBER")
Call UpdateCopiedModelPropertiesConventional(a, "TITLE")
MsgBox ("ready")
End Sub
Public Sub UpdateCopiedModelPropertiesConventional(oInvApp As Inventor.Application, Prop As String)
        Dim oDrawDoc As Document 'DrawingDocument
        oDrawDoc = oInvApp.ActiveDocument
        If Not oDrawDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
            Exit Sub
        Else
        'get active sheet
        Dim oDwgSheet As Sheet
        oDwgSheet = oDrawDoc.ActiveSheet
        'get the active component in the view
        Dim oCompObject As Document
        oCompObject = oDwgSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
        Dim oCompObjectPrpset As PropertySet
        oCompObjectPrpset = oCompObject.PropertySets.Item("User Defined Properties")
        Dim oCompObjectPrp As Inventor.Property
        On Error Resume Next
        oCompObjectPrp = oCompObjectPrpset.Item(Prop)
        Dim oDwgD As String
        oDwgD = oCompObjectPrp.Value
        Dim odrawInvPropSet As PropertySet
        odrawInvPropSet = oDrawDoc.PropertySets.Item("User Defined Properties")
        Dim odrawInvProp As Inventor.Property
       Call odrawInvPropSet.Add(oDwgD, Prop)
       odrawInvProp = odrawInvPropSet.Item(Prop)
        If Not oDwgD = odrawInvProp.Value Then
            'fill in the desciption from the component into the Dwg description
            odrawInvProp.Value = oDwgD
            MsgBox ("The description of the drawing: " & odrawInvProp.Value)
        oDrawDoc = Nothing
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 26
mrawesomelemons
If I understand correctly this updates the custom properties I listed?
It cannot enable the custom property in the drawing?
Message 17 of 26
bradeneuropeArthur
what do you mean with "It cannot enable the custom property in the drawing?"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 26
mrawesomelemons
I mean it doesn't enable the checkbox I marked earlier. When I run the script on a drawing where the cusom properties are disabled in document settings I do see the pop up but when I check it isn't enabled.
Message 19 of 26
bradeneuropeArthur
As I already wrote earlier:
"As far as I know this is not possible.
If iIam remembering correct this was also confirmed that this is not included in the API (Application Programming Interface) if inventor.."
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 26
mrawesomelemons
Ah yeah okay. Thank you for your code to update the properties and your help! Maybe Autodesk will add the possibility later.
