Enable and Disable Inventor Add-In Programmatically?
jandrewsKUX78
jandrewsKUX78
Is it possible to disable and enable Inventor (2022) add-ins via any API mechanism?
I want to do what is shown below programmatically because when a custom Vault add-in I developed runs, it launches Inventor via COM and if the Data Standard is enabled in Inventor, it pops a login dialog that the customer does not want to see:
Curtis_W
Hi @jandrewsKUX78
see this link
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/unload-add-in-using-vba/m-p/8078384#...
I hope this helps.
Curtis
JelteDeJong
there are 2 more options. if you know the guid of the addin then you can use this:
(The guid is always in the .addin file)
Dim addin As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{34fa5034-811e-426f-8f01-42187b25e221}")
addin.Deactivate()
but you can also search for it by name without the loop:
	ApplicationAddIns.
	Cast(Of ApplicationAddIn).
	Where(Function(a) a.DisplayName.Equals("MyAddin", StringComparison.InvariantCultureIgnoreCase)).
	FirstOrDefault()
addin.Deactivate()
Jelte de Jong
Blog: hjalte.nl - github.com
JMGunnar
Function too get add ins
Sub Main()
		Dim _VaulAddin As Inventor.ApplicationAddIn
		Try
			_VaulAddin = GetAddinByByName("Inventor Vault")
			_VaulAddin.Deactivate
		Catch
		End Try
		'***************** here is the ordinary code  *******************
		Try
			_VaulAddin.Activate
		Catch
		End Try
	End Sub
		'***************** the function *******************
	Function GetAddinByByName(displayName As String) As Inventor.ApplicationAddIn
        For Each i As Inventor.ApplicationAddIn In ThisServer.ApplicationAddIns
            If i.DisplayName = displayName Then
                Return i
            End If
        Next
        Return Nothing
    End Function
jandrewsKUX78
Thank you all for your replies - Jelte's seems the most elegant, but they are all helpful and get the job done!
