Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Rename only circular pattern solids
manu.marjanen
Message 1 of 8
manu.marjanen
How can i rename only circular pattern solids?
for example, Circular pattern1 solid names from Part01...Part10
Replies (7)
Message 2 of 8
Michael.Navara
This renames newly created SurfaceBodies except the first one (source body)
Dim part As PartDocument = ThisDoc.Document
Dim circPattern = part.ComponentDefinition.Features.CircularPatternFeatures(1)
Dim i As Integer = 1
For Each surfBody As SurfaceBody In circPattern.SurfaceBodies
	surfBody.Name = String.Format("Part_{0:0#}", i)
	i += 1
Next
Message 3 of 8
manu.marjanen
Almost good.
Now, indeed, the first part does not get a new name.
Does anyone get the modified code so that the name of all the parts changes?
Message 4 of 8
Curtis_W
Hi @Michael.Navara
Try this update to Michael.Navara's example.
I hope this helps.
Curtis
circPattern.Parent.SurfaceBodies.Item(1).Name = String.Format("Part_{0:0#}", i)
	i += 1
Next
Message 5 of 8
manu.marjanen
The names of the first circular pattern change correctly.
But the name of the first part of the second circular pattern does not change.
Message 6 of 8
A.Acheson
To add to the guys work this is why only the first pattern was targeted where (1) is the first in the CircularPatternFeatures collection.
Here it is for all patterns just loop through the CircularPatternFeatures collection
For Each circPattern As CircularPatternFeature In part.ComponentDefinition.Features.CircularPatternFeatures
		i += 1
	Next
Next
Regards
Alan
Message 7 of 8
manu.marjanen
I want to rename different circular patterns with different names,  this does not work for it.
for example.
Circular pattern 1: Plate_1_01 ... Plate_1_10 (10 plates)
Circular pattern 2: Plate_2_01 ... Plate_2_05 (5 plates)
Can you edit the code to make it work this way?
Message 8 of 8
Curtis_W
Hi @manu.marjanen ,
Give this example a try.
I hope this helps.
Curtis
Dim j As Integer = 1
	circPattern.Parent.SurfaceBodies.Item(1).Name = String.Format("Plate_" & j & "_{0:0#}", i)
		i += 1
		surfBody.Name = String.Format("Plate_" & j & "_{0:0#}", i)
	Next
	j += 1
Next
