Editing the Default.ivb
I have a code that works very well when you place it in a (VBA)Module called
"Functions", but I want to place that piece of code into the Deault.ivb.
Public Function ist(Arg1 As Double, Arg2 As Double, Arg3 As Double, Arg4 As
Double) As Double
'If the Arg1 is Smaller Then Arg2 the result is Arg3 otherwise Arg4.
If Arg1 < Arg2 Then
ist = Arg3
Else: ist = Arg4
End Function
Problem is: it doesn't work! Do I have to do something more than just
copy-past the code in the Default.ivb?
Thanks alot,
T. Ham
Mechanical Engineer
CDS Engineering BV
Just one addition: I use this code in parts to "drive" my dimensions.
"Hamster" wrote in message
news:53800A2B5BF3FA30F534C48102F45F86@in.WebX.maYIadrTaRb...
> Hi,
called
As
> Double) As Double
> If Arg1 < Arg2 Then
> ist = Arg3
> Else: ist = Arg4
> End If
> End Function
> Thanks alot,
> T. Ham
> Mechanical Engineer
> CDS Engineering BV
Functions that are called as part of a parameter expression must exist
within the document they're referenced in. This allows the document to be
self-contained with regards to being able to compute itself.
-Brian
news:91372B05A5B7161B9E88F821A8C544FC@in.WebX.maYIadrTaRb...
> > Hi,
> called
> As
> > Double) As Double
> > If Arg1 < Arg2 Then
> > ist = Arg3
> > Else: ist = Arg4
> > End If
> > End Function
> > Thanks alot,
> > T. Ham
> > Mechanical Engineer
> > CDS Engineering BV
So it is not possible to reference this VBA Function from the Deault.ivb?
Hmm, in that case the VBA Function has to be copied to each part/assembly if
it is going to be used.
Thanxs for the info!
"Brian Ekins (Autodesk)" wrote in message
news:B5A82E98F88B8E28E7F311F51E9BACF5@in.WebX.maYIadrTaRb...
> -Brian
> > > Hi,
> > called
Deault.ivb.
Arg4
> > As
> > > Double) As Double
Arg4.
> > > If Arg1 < Arg2 Then
> > > ist = Arg3
> > > Else: ist = Arg4
> > > End If
> > > End Function
> > > Thanks alot,
> > > T. Ham
> > > Mechanical Engineer
> > > CDS Engineering BV
Or placed in the part template file so when you create a new part file it's
already in the document's function node.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
news:7A4C04A063B987A4D88A12CE4EF0F991@in.WebX.maYIadrTaRb...
if
be
> > -Brian
> > > > Hi,
(VBA)Module
> > > called
> Deault.ivb.
> Arg4
> > > As
> > > > Double) As Double
> Arg4.
> > > > If Arg1 < Arg2 Then
> > > > ist = Arg3
> > > > Else: ist = Arg4
> > > > End If
> > > > End Function
just
> > > > Thanks alot,
> > > > T. Ham
> > > > Mechanical Engineer
> > > > CDS Engineering BV
Sorry for the late reply, but thanks Sean!
I will have to copy the VBA-Function code to the Part, Sheetmetal, Assembly
and WeldAssembly Document.
Thanks again.
"Sean Dotson" wrote in message
news:21A349443E41BF1CEE09C991538F9E6A@in.WebX.maYIadrTaRb...
it's
> Sean Dotson, PE
Deault.ivb?
part/assembly
> if
to
> be
> > > -Brian
dimensions.
> > > > > Hi,
> (VBA)Module
> > > > called
> > Deault.ivb.
Double,
> > Arg4
> > > > As
> > > > > Double) As Double
> > Arg4.
> > > > > If Arg1 < Arg2 Then
> > > > > ist = Arg3
> > > > > Else: ist = Arg4
> > > > > End If
> > > > > End Function
> just
> > > > > Thanks alot,
> > > > > T. Ham
> > > > > Mechanical Engineer
> > > > > CDS Engineering BV
