create base view - idw
is it possible to create base views using vba, and then can you create views
off of that view?
i didnt find any samples in the help file that delt with views at all.
thanks
Matt
Matt,
Here is some VB code that will create a drawing, then add views to that drawing.
Private Sub cmdCreateDWGSheet_Click()
If oApp.ActiveDocument Is Nothing Then
MsgBox "The active document must be a 'part' document"
Exit Sub
If oApp.ActiveDocument.DocumentType <> kPartDocumentObject Then
Exit Sub
Dim oPartDoc As PartDocument
Set oPartDoc = oApp.ActiveDocument
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = oApp.Documents.Add(kDrawingDocumentObject, oApp.FileManager.GetTemplateFile(kDrawingDocumentObject))
Dim VScale As Double
VScale = 0.11
Dim lHoriz As Long
lHoriz = 10
Dim lVert As Long
lVert = 15
Dim oDrawingViews As DrawingViews
Dim oDV As DrawingView
Set oDrawingViews = oDrawingDoc.Sheets(1).DrawingViews
Dim V_Org As Point2d
Set V_Org = oApp.TransientGeometry.CreatePoint2d(lHoriz, lVert)
Set oDV = oDrawingViews.AddBaseView(oPartDoc, V_Org, VScale, kLeftViewOrientation, _
kHiddenLineRemovedDrawingViewStyle)
Set V_Org = oApp.TransientGeometry.CreatePoint2d(lHoriz + 20, lVert)
Set oDV = oDrawingViews.AddBaseView(oPartDoc, V_Org, VScale, kFrontViewOrientation, _
Set V_Org = oApp.TransientGeometry.CreatePoint2d(lHoriz, lVert + 18)
Call oDrawingViews.AddProjectedView(oDV, V_Org, kIsoTopLeftViewOrientation, _
kHiddenLineRemovedDrawingViewStyle, VScale)
End Sub
thanks alot  🙂
Matt,
drawing.
        MsgBox "The active
        Exit Sub
        MsgBox "The active
        Exit Sub
    Set oPartDoc =
oApp.ActiveDocument
    Set
    VScale = 0.11
Dim lHoriz As Long
    lHoriz = 10
    Dim lVert As Long
    lVert = 15
    Dim oDV As
DrawingView
    Set oDrawingViews =
    Set V_Org =
_
VScale)
End Sub
clu82,
I really like this code and I'm trying to do the same as the other user. We only create individual part drawings that require machining. A Plan, Top, Side and 2 Iso views. We do this manual. I tried this code the way it is and I keep bombing at the"AddProjectedView" line. (even other posts w/ "AddProjectedView" I can not get by this one line. Whats wrong here? I have inv11 w/sp3. Thanks in advance. Tim
The macro is using an older (obsolete) signature for AddProjectedView. The
new signature has one argument less (the view orientation is gone). this
should work:
Call oDrawingViews.AddProjectedView(oDV, V_Org, _
Sanjay-
wrote in message news:5739570@discussion.autodesk.com...
clu82,
This correction gets me on my way. Thank you.
