Part or Assembly
Part or Assembly
Part or Assembly
Hi group!
Is there a property of a drawing document that would tell me if it's a
drawing of a part component or an assembly component?
Thanks in advance.
Tim Strandberg
Tim:
Could you use this testing method to see the referenced file type?
If ThisApplication.ActiveDocument.ReferencedFiles.Count >= 1 Then
If LCase(Right$(ThisApplication.ActiveDocument.ReferencedFiles.Item(1).DisplayName, 3)) = "iam" Then
MsgBox "This drawing containes an Assembly Document."
ElseIf LCase(Right$(ThisApplication.ActiveDocument.ReferencedFiles.Item(1).DisplayName, 3)) = "ipt" Then
MsgBox "This drawing containes a Part Document."
Lian
One thing to be aware of is that drawings can
reference multiple documents and they can be of different types.  So, you
can have a drawing that references parts and assemblies.
Assuming you have one reference in your drawing,
Lian's approach will work.  One slight change is to check the document type
directly using the DocumentType property.
If
Then
     If
ThisApplication.ActiveDocument.ReferencedFiles.Item(1).DocumentType =
kAssemblyDocumentObject
Then
     If
kPartDocumentObjectThen
        MsgBox
     End
If
-Brian
Tim:
     If
3)) = "iam" Then
        MsgBox
     ElseIf
3)) = "ipt" Then
        MsgBox
Lian
