EDited
EDited
haphanthanhtam.work
EDited
haphanthanhtam.work
EDited
Andrii_Humeniuk
Hi @haphanthanhtam.work . Please try this code, is it what you need?
Step 1 - choose your components, step 2 - run the code.
Sub main
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If TypeOf oDoc Is AssemblyDocument Then
		Dim oADoc As AssemblyDocument = oDoc
		Dim oSS As SelectSet = oADoc.SelectSet
		If oSS.Count = 0 Then Exit Sub
		Dim sParam As String = InputBox("Prompt", "Mi-Logic", "Purt number")
		If String.IsNullOrEmpty(sParam) Then Exit Sub
		Dim oOcc As ComponentOccurrence
		Dim oOccsList As New List(Of ComponentOccurrence)
		Dim i As Integer
		For i = 1 To oSS.Count
			If oSS.Item(i).Type = ObjectTypeEnum.kComponentOccurrenceObject Then
				oOccsList.Add(oSS.Item(i))
			End If
		Next i
		Dim oOccDoc As Document
		For i = 0 To oOccsList.Count -1
			oOcc = oOccsList.Item(i)
			If Not oOcc.Suppressed Then
				oOccDoc = oOcc.Definition.Document
				If Not oOccDoc.IsModifiable Then Continue For
				oOccDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = sParam
			End If
		Next i
		oADoc.Update()
	End If
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
haphanthanhtam.work
Thank you @Andrii_Humeniuk
It''s perfect
You can add Description more
And finally, it will automatically hide the selected sections.
Andrii_Humeniuk
I added the "Description" property entry, but I don't understand what you mean by "automatically hide the selected sections". Do you want your components to be invisible or hidden after the rule is executed? In the code, line 26 is responsible for visibility, and line 27 for its suppression.
Sub main
		Dim sPurtNumb As String = InputBox("Prompt", "Mi-Logic", "Purt number")
		If String.IsNullOrEmpty(sPurtNumb) Then Exit Sub
		Dim sDesc As String = InputBox("Prompt", "Mi-Logic", "Description")
		If String.IsNullOrEmpty(sDesc) Then Exit Sub
		Dim i As Integer
			End If
		Next i
				Dim oOccDoc As Document = oOcc.Definition.Document
				oOccDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = sPurtNumb
				oOccDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value = sDesc
				oOcc.Visible = False
'				oOcc.Suppress(True)
			End If
		Next i
		oADoc.Update()
	End If
End Sub
haphanthanhtam.work
I want it to be invisible
So that I can continue to assign values ​​to other Parts
it works great!!!
Thank you so much !!!! @Andrii_Humeniuk
