Edit parts material via BOM
Message 1 of 14
my name is Nicola, I am new to this forum and in need of some hints.
I am working on an assembly with some subassemblies. My goal is to change the material of some parts by using the runtime adjustment column found in the BOM. This works fine, but some parts seem to be write protected.
I found out that parts are protected in the BOM when they appear in more than one instance and in different subassemblies (SA). Just like this:
Main Assembly
- SA 1
  - Part 1
  - Part 2
- SA 2
  - Part 3
  - Part 1
Part 1 will be protected in the BOM. Opening the SA and editing its BOM is possible, but not so convenient.
The parts do not occure in any libraries, they are just simple sheet metal parts drawn by me.
Is there a way to set the material properties for all parts in the BOM of the main assembly?
Any help is very much appreciated.
Nicola
Replies (13)
Message 2 of 14
bradeneuropeArthur
You better use the PartsOnly Bom.
this will list only the parts and their material.
if you need further support please let me know.
hope this will solve your problem.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
thank you for your reply. I think I am already using the parts BOM. Please take a look at the picture.
Message 4 of 14
bradeneuropeArthur
You could also use the:
dim part as Inventor.partdocument = ...Bomrow.componentdefenition.document
part.open
than changing the material......
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
Hm, I don't exactly know what you mean, but it looks a bit like ilogic to me. I would prefer to change the material by using ilogic anyway, but I failed to get the code to work. I tried to adapt the code below.
I changed it by adding an if-then statement to change material only if the "old" material number is either 1.4301 or 1.4571 to prevent the code from changing all the other, non-steel parts too.
"YOUR MATERIAL HERE" was replaced by a string parameter.
Didn't work, that's why I tried the BOM method.
' Get the active assembly document.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the material to assign to all of the parts.
    Dim strMaterialName As String
    strMaterialName = "YOUR MATERIAL HERE"
    Dim oMaterial As Material
    On Error Resume Next
    ' Try to get the material of the specified name.
    oMaterial = oAsmDoc.Materials.Item(strMaterialName)
    On Error Goto 0
    ' Iterate through all of the documents refrenced by the assembly.
    Dim oDoc As Document
    For Each oDoc In oAsmDoc.AllReferencedDocuments
        ' Check to see if this is a part.
        If oDoc.DocumentType = kPartDocumentObject Then
            Dim oPartDoc As PartDocument
            oPartDoc = oDoc
            ' Set the material.
            oPartDoc.ComponentDefinition.Material = oMaterial
    Next
Message 6 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Hoping that below iLogic code will work for you.
    On Error Goto 0
            oPartDoc = oDoc
            ' Set the material.
            oPartDoc.ActiveMaterial= oMaterial
    Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 14
Hello Chandra,
please apologize my late reply, I wasn't at the office for a few days..
Thank you very much for your help, but unfortunately there still seems to be an error somewhere.. I copied your code an replaced the string for the material and I got an error message stating:
Error in Rule: test in document: test.iam The COM object of type "System .__ ComObject"
can not be converted to interface type "Inventor.Asset". This operation could not be
performed because the QueryInterface call to the COM component for the interface with the
IID "{766A9447-A604-43C8-9393-2D2709837D1E}" failed because of the following error:
Interface not supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
 I translated the error description from German via google translator, so I hope it makes any sense.
By the way: is it possible to adapt the code to change the material only if the part already has a specific material? It should look something like this (please take a look at my remarks in green):
            oPartDoc = oDoc
            ' Set the material.
if oPartDoc.ActiveMaterial = "1.4301" or oPartDoc.ActiveMaterial = "1.4571" then oPartDoc.ActiveMaterial= oMaterial
end if End If
This would be better because the code should change only steel parts which are either 1.4301 or 1.4571. No other materials should be changed.
Many thanks in advence!
Nicola
Message 8 of 14
I tried to find the line containing the error, it seems to be
oPartDoc.ActiveMaterial = oMaterial
If this is commented out the code runs without errors.
Nicola
Message 9 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Please provide sample assembly file to test and make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 14
marcin_otręba
I think that problem is because you set material from assembly and try to add it to sub part.
Try:
    Set oAsmDoc = ThisApplication.ActiveDocument
    strMaterialName = "cartboard"
    Dim oMaterial As MaterialAsset
          Set oPartDoc = oDoc
                Dim localAsset As MaterialAsset
                Dim localAsset1 As MaterialAsset
                Set localAsset = oAsmDoc.MaterialAssets.Item(strMaterialName)
                Set localAsset1 = localAsset.CopyTo(oPartDoc, True)
               oPartDoc.ActiveMaterial = oPartDoc.MaterialAssets.Item(strMaterialName)
    Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 11 of 14
Hello Marcin,
thank you very much, the code works. i just had to remove the "set"-statements.
It would be very nice if you could change the code a little bit: The material should only be changed if it is either material 1.4301 or material 1.4571. I do not know how to set up the correct syntax for the if...end if loop.
It should look something like this:
end if
Many thanks in advance
Nicola
Message 12 of 14
Hello Chandra,
thank you very much for your reply. Marcin just posted a working code, it seems that his thoughts regarding the access from .iam to .ipt were right.
I will upload my test assembly anyway, maybe it is still needed.
Nicola
Message 13 of 14
marcin_otręba
          Set oPartDoc = oDoc
          if oPartDoc.ActiveMaterial.name = "1.4301" or oPartDoc.ActiveMaterial.name = "1.4571" then
          end if
    Next
Message 14 of 14
Hello Marcin,
thank you very much for your help. Everything is working as expected now!
Best regards
Nicola
