Edit an existing Extrusion with Ilogic / vba
Message 1 of 8
i have an existing Extrusion. I won't to change this from increase to cut out.
The name of the Extrsion is "Bohrungen"
SourceSource
Won't change to:
Hole thrue allHole thrue all
I have found a code that change the direction but i don't know to change the extrusion to Cut thrue.
Here is the code that i have now:
SyntaxEditor Code Snippet
Sub Main
 Dim extrude As ExtrudeFeature = TryCast(Feature.InventorFeature("Bohrungen"), ExtrudeFeature)
 Dim extent As DistanceExtent = TryCast(extrude.Extent, DistanceExtent)
If Noppen = True Then
 extent.Direction = PartFeatureExtentDirectionEnum.kPositiveExtentDirection
Else
extent.Direction = PartFeatureExtentDirectionEnum.kNegativeExtentDirection
End If
End Sub
I have tested with the kCutOperation, but i don't know how?
Sincerely
Replies (7)
Message 2 of 8
JamieVJohnson2
I created a deck feature using this method.  The 'Operation' property of the ExtrusionDefinition of the ExtrusionFeature is what you are after aka ExtrudeFeature.Defnition.Operation
        Dim edDeck As ExtrudeDefinition = cdCarDeck.Features.ExtrudeFeatures.CreateExtrudeDefinition(skDeckProfile.Profiles.AddForSolid, PartFeatureOperationEnum.kNewBodyOperation)
                    edDeck.SetDistanceExtent(RowCar.DeckWidth * 2.54, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
                    Dim efDeck As Inventor.ExtrudeFeature = cdCarDeck.Features.ExtrudeFeatures.Add(edDeck)
                    extrusionDefinition.Operation=PartFeatureOperationEnum.kCutOperation 'and all other types
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 3 of 8
lzs013
ExtrudeDefinition Object
Operation
Read-write property that gets and sets the type of operation used to add the feature to the model. Valid inputs are kNewBodyOperation, kJoinOperation, kCutOperation, kIntersectOperation and kSurfaceOperation.
Message 4 of 8
thank you for your help 🙂
I only have a little problem.
I have change the Operation to kCutOperation, thats work fine, but i won't that there is no distance - only thrue all.
Can you help me again? Witch parameter is responsible for the "thrue" option?
Thanks 🙂
Sincerely
Message 5 of 8
lzs013
oEF = Feature.InventorFeature(“Bohrungen”)
oEF.Definition.SetThroughAllExtent(kNegativeExtentDirection)
oEF.Operation = kCutOperation
Message 6 of 8
Thanks so much!
Now it works and i know why. Smiley Very Happy
Sincerely
Message 7 of 8
HI there, I'm building a very simple illogic rule to turn features on and off based on a parameter. in one case I need to flip one of the extrude features. I'm unsure how to insert your code into my rule can you provide some guidance?
If Vertical_Divider = "Full" Then
Feature.IsActive("vDivider Base") = True
Feature.IsActive("vDivider Top") = True
ElseIf Vertical_Divider = "None” Then
(here I need to flip the vDivider Base asymmetric extrusion from 9,0.5 to 0.5,9)
Feature.IsActive("vDivider Top") = False
ElseIf Vertical_Divider = "Upper" Then
Feature.IsActive("vDivider Base") = False
End If
Thanks for your help
Message 8 of 8
lzs013
vDividerBase=Feature.InventorFeature("vDivider Base")
vDividerBase.Definition.SetDistanceExtentTwo = 0.9
vDividerBase.Definition.SetDistanceExtent = 0.05
